Originally Posted by
junebug7173
I have looked all over the internet to see how to resolve this problem. I have tried about all techniques listed out there. Tested the Samsung Charger with USB voltage tester and it was reading just below 5 volts.
If you're using 5.3 Volt charger, it should read around 5.2--> 5.3 V, current should be around 1.7Amperes
Even 5 Volt charger, you should have at least 5 volts, anything under 5 Volts, something is wrong with your charger.
Try another charger, USB cable one by one to see anything is different.
If using known working USB cable and charger makes no different, you should try to change USB flex charging port, around $5 to $10,
If your tablet is charging when it's off, press the HOME button, it should show the green battery icon like this when it's full charge.
These troubleshoot steps you should do by yourself, no one can help or guess with many unknowns.
Post what you did and results may help me to assist you further, if you're doing correctly elimination method one by one, the problem can narrow down to the defective part : USB cable or charger or charging port or battery connector.
Guessing cannot solve your problem, if you have a cracked battery connector: remove the back cover, pressing directly on the battery connector and power on, it will help the tablet to turn on.
With available working parts, I can find the problem within 5 to 10 minutes.
