1. aaronh94's Avatar
    Hi, im new here =]
    I couldnt find the tab pro in the search bar so this is the closest one to it.
    I bought this off the net and I love it, but the battery is crazy! ive tried to get a hold of the guy but he wont answer me.
    The battery is after 20 percent dies after 2 mins or so, and then when i turn it back on its on 32 percent!?!? then after that has drained fast and turned off its back on like 20-30 percent.. Is there any way I can fix this?
    thanks guys
    09-09-2016 04:25 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved to the Tab Pro 8.4 forum.
    You could try recalibrating the battery sensor software by charging to 100%, then using it normally until it shuts off from low battery, then charging back up to 100%. You might have to do this cycle a couple of times. If the problem persists, then it's more likely that the battery is starting to fail, and is having problems holding as full a charge as it used to.
    09-10-2016 03:43 AM
  1. Samsung galaxy s7 music folder
    By Ruby_Soho in forum Samsung Galaxy S7
    Last Post: 09-09-2016, 11:13 PM
  2. Galaxy Tab Pro 8.4" Battery inconsistencies
    Last Post: 09-09-2016, 05:13 PM
  3. Why is my battery life draining so quickly?
    Last Post: 09-09-2016, 01:51 PM
  4. Why my Galaxy Note 4 is overheating when I don't use it?
    Last Post: 09-09-2016, 01:37 PM
  5. Nexus 6P and huawei watch battery drain
    By celticfdguy in forum Nexus 6P
    Last Post: 09-09-2016, 01:27 PM
