Prime Day deal: Save $200 on the Samsung Galaxy S21
  1. yubeie's Avatar
    My galaxy tab s (stock and not rooted) has a kernel wake lock "sec-battery-monitor" causing a huge drain. Tried searching on Google/xda with no information.
    Gsam battery monitor shows this wake lock. I've made sure the are no battery Widgets, battery reporting, optimizing apps being used.
    Would anyone please explain what this wake lock does?
    AC@OPO
    02-21-2015 07:59 AM
  2. Golfdriver97's Avatar
    There always is a report from the battery. In fact, you would arguably have 2: the stock one, and GSAM. Have you tried rebooting the device?
    02-21-2015 08:37 AM
  3. yubeie's Avatar
    Yes, I did. I was under the same impression. But the strange thing is that i don't see this wakelock on my oneplus one which is also running gsam. Why the difference?
    Thanks!
    AC@gtabs10.5
    02-22-2015 09:18 PM
  4. Golfdriver97's Avatar
    Thanks!
    AC@gtabs10.5
    Can you show a picture of the wakelock screenshot from GSAM?
    02-22-2015 10:11 PM
  5. yubeie's Avatar
    Attached is the screenshot.. Thanks! Fyi.. I uninstalled gsam and now using bbstats and i rooted the device so that i can get more details... BB stats also tells the same story
    AC@gtabs10.5
    Attached Thumbnails Battery drain :(-screenshot_2015-02-23-19-20-23.jpg
    bywasabi likes this.
    02-23-2015 06:23 PM
  6. yubeie's Avatar
    More info.. Notice the tablet is awake 2.5 hrs and the screen was on for only 6mins...
    AC@gtabs10.5
    Attached Thumbnails Battery drain :(-screenshot_2015-02-23-19-24-50.jpg   Battery drain :(-screenshot_2015-02-23-19-20-23.jpg   Battery drain :(-screenshot_2015-02-23-19-25-08.jpg
    02-23-2015 06:26 PM
  7. ignativss's Avatar
    Hi there, did you find how to solve the problem with this "sec-battery-monitor" wakelock? I am suffering the exact same problem in Note 3 (SM N900) and I have tried almost everything (except flashing a new kernel, there is no kernel available for Lollipop yet). Nevertheless, I could gain some extra hours by freezing (with Titanium Backup) the "Google App". Now I can hit almost 20 hours with average use, but the main problem is this "sec-battery-monitor" thing that keeps my device awake 100% of the time.
    Regards!
    04-01-2015 10:42 PM
  1. How do I open the Coolpad Arise to insert battery?
    Last Post: 11-13-2015, 06:05 PM
  2. How do I bypass having a battery?
    Last Post: 02-21-2015, 08:42 PM
  3. Android system killing my battery.
    By Jannukaz in forum Samsung Galaxy S5
    Last Post: 02-21-2015, 02:07 PM
  4. Battery usage: Typical?
    By orangesky in forum Google Nexus 5
    Last Post: 02-21-2015, 07:40 AM
  5. Replies: 1
    Last Post: 02-21-2015, 06:31 AM
