1. b-16707's Avatar
    Im assuming the battery is dead on this but before i go buy a new battery i just wanted to get some confirmation if anyone has experienced this before.
    • tablet asked to restart. i assume after an update, not sure as my parents were using it and they are bad at english so i have no idea what happened. Tablet blacks out after hitting restart is what my parents told me
    • connected the charger and nothing, no power button works, no pwr+vol works, etc nothing works to force restart or get into recovery works
    • so I pryed the back open, disconnected the battery. Let it be for a couple minutes
    • plugged in the tablet and tested to see if it will boot without battery connected. It shows the power icon and does an endless "boot" of that icon but doesnt boot anywhere near the OS
    • connected back the battery and it shows the power icon with 91% but doesnt charge past that (if it is charging??) even if i leave it for an hour
    So my question is, im assuming the tablet needs a good battery to boot into the OS? even if the battery registers 91% and has power but doesnt charge, that means its a bad battery and the tab wont boot? Are my assumptions legit?
    Thanks!
    09-04-2017 09:49 PM
  2. b-16707's Avatar
    update, looks like the battery is taking a charge! still wont boot into OS though no matter what button combo or length of hold i use...
    If unplugged from the charger, nothing woks and it always has no screen/black
    09-04-2017 09:50 PM
  1. Battery Issues with Flashlight App
    By Moondoggy in forum Motorola Droid Turbo
    Last Post: 12-01-2017, 06:34 AM
  2. Usbc Charging earbuds?
    By Final-MacGyver in forum Headsets
    Last Post: 10-31-2017, 07:07 PM
  3. Help - Tab S2 keeps losing/freezing wifi connection
    By lokoroxbr in forum Samsung Galaxy Tab S2
    Last Post: 09-08-2017, 10:49 AM
  4. Is it ok to charge your phone from 80% or 90% to 100%?
    By Adrian Abaja in forum General Help and How To
    Last Post: 09-04-2017, 06:57 PM
  5. Screen on. When charging
    By fitcherama in forum Samsung Galaxy S8 & S8+
    Last Post: 09-04-2017, 03:24 PM
