resolution difference between S2 and the older 8.4" model
I ran Galaxy Tab S Pro 8.4" which had that absolutely brilliant 2560x1600 resolution. The screen was the best I've ever seen. It generated that "wow" factor every time I looked at it and nothing else came close.
it had several problems however. Battery life was terrible and got even more so as it aged. At the end of 3 years, it lived off the charger.
isthisretina.com shows that Pixels per inch went from 360 to about 320 a bit worsening pic quality but that may not be a bad thing because with lower number of pixels, it may get better runtime. The higher the resolution, the higher the drain on the battery.
Second, I did not like the 16:10 ratio at all, I think 4:3 makes so much more sense for everything except movie-watching which I didn't do anyway. 16:10 was difficult to type on. I seriously considered ipad mini 4 to get the 4:3 ratio until I realized S2 offered that ratio and then jumped on S2.
Re: resolution difference between S2 and the older 8.4" model
I just purchased the S2 to replace my aging 8.4 and so far I find the screen looks better on the S2.
I too just bought an S2. I'm keeping my Tab S because I still love it, I used it for over three years after all.
It's taking a little getting used to the squarer aspect ratio but I have no complaints at all about the screen and it's quality. It's gorgeous.
