1. GalaxyLooney's Avatar
    I have been keeping a spreadsheet to monitor my battery drain (I know I'm sad).
    Prior to the 12th my average drain was around 1.4% per hour.
    Since then it has jumped to around 2% per hour.
    Is there anything that could have caused the increase? I can't remember when the software updated but am sure it was before this. I have made sure apps are closed and even rebooted the watch.
    02-14-2019 07:09 AM
  2. methodman89's Avatar
    Go to Settings, battery, usage, and let us know.
    02-14-2019 07:33 AM
  3. Peter621022's Avatar
    Did you change or update the watch face that you're using by any chance?
    02-14-2019 10:23 AM
  4. GalaxyLooney's Avatar
    I haven't changed anything. Under Battery it has default 1d 1h 49m and I'm currently on 35%. I'll have to keep tabs on it but it's odd it just jumped up for no apparent reason.
    02-14-2019 12:55 PM
  5. Greymire's Avatar
    Sounds like a full factory update is in order. Back up your watch in Galaxy app then use the buttons to do a full reset. The button process is a bit annoying and can take a few tries to get it to work.. There is a reset on the settings but it isn't a full reset and you still need to backup so I am not sure why it's even there.
    GalaxyLooney likes this.
    02-15-2019 05:34 AM
  6. arunma's Avatar
    Not sure that the battery is actually degrading. Might just be the software inference of the battery percentage remaining.
    Case in point. I use AOD on my watch, and I just reset it last week because i connected to a new phone. Today the battery drained at 2.5% per hour. Yesterday it was 3.5% The day before that it was about 2.4% Clearly there are some confounding factors here. But I'm not sure I'd worry about it.
    02-16-2019 12:21 AM
  7. GalaxyLooney's Avatar
    It has settled down a bit with although I had a high of 3.8% and low of 1.15% (but that was last night). I'm pretty much averaging 1.5% ph over the whole period. I'm not sure how some people are getting 3 days from it. 2 days and I need to charge. I'm glad I didn't go for the 42mm now.
    02-17-2019 06:40 AM
  1. Replies: 2
    Last Post: 02-14-2019, 05:36 AM
  2. Replies: 1
    Last Post: 02-13-2019, 02:29 PM
  3. My samsung tab A 10.1 has a new touch that does not work after installation.
    Last Post: 02-13-2019, 11:39 AM
  4. Replies: 1
    Last Post: 02-12-2019, 11:49 PM
  5. Replies: 1
    Last Post: 02-12-2019, 01:54 PM
