Anyone able to get Gboard to work on the z flip 3? When I go into settings, only the samsung keyboard is listed. Anyone have a workaround to get this to work?
Search for it in the Play Store and see which options you get (Install/Open/Enable ...)Correct, only option showing is Samsung keyboard.
So u tap on default keyboard and no option? When I tap that it pulls my 3 optionsView attachment 339302
Yeah you'll have teast what works better for you as you now have Google and Samsung options .That's one thing I'll have to get used to, there's so many more options on a Samsung phone for things than a pixel. And I have no idea if Samsung's versions are better than Google's or not. This should be interesting lol.
On a side note, can I set my unlocked Z Flip 3 up over wi-fi without a sim card in it? That's how I usually do it to keep my old phone working so I won't miss calls, and keep the new phone setup from being interrupted, but I know Samsung's have a Samsung account I guess I need to setup as well as my Google account? Plus I don't know if they'll update without a sim in them?
Then u don't have gboard installedCorrect, only option showing is Samsung keyboard.
Try this go to settings>general management>reset>reset settingsYes, it's installed. I've done web searches and it seems it's a z flip issue.
Yes without sim you can do set-up and updates for software and apps will update without sim and just wifi.
Definitely make a Samsung account that it can sync things not just Google doing basic syncing
Im here to helpThanks Mustang, I told you I'd have some Samsung questions lol. I'm glad we have a Samsung specialist like you around
