1. missionsparta's Avatar
    Does anyone know if when you are using split screens and more than one has audio, is there a way to mute or select which one is playing the audio?
    09-18-2021 01:41 PM
  2. mustang7757's Avatar
    I'm not clear what you mean?
    09-19-2021 01:42 AM
  3. bandofbrothers2112's Avatar
    I think the op means if you open two apps on the inner screen thus using split screen and both are playing different audio can you choose which one to listen to.
    09-19-2021 04:40 AM
  4. bkdodger2's Avatar
    Whichever app you tap on split screen will play and if you tap on other then that one will play and continue...
    kevinpleasants likes this.
    09-19-2021 08:52 AM
  5. TMavC5's Avatar
    Trying to figured out why he would want this feature. I can only listen one audio or video at a time. I think he wants to know how to disable one of the audio or video when both apps are running.
    My solution, don't open one and finish one and start the next.
    09-19-2021 11:01 AM
  6. mustang7757's Avatar
    Never used it that way
    bandofbrothers2112 likes this.
    09-19-2021 10:11 PM
  7. missionsparta's Avatar
    Those asking why, I've been running two sports apps with events actually playing on both.....problem is while both videos running at the same time is awesome, the audio playing on both isn't ideal.
    09-19-2021 10:32 PM
  8. cleankutazn's Avatar
    Same here, I tried watching HBOMAX and a Youtube video. I couldn't mute one of the videos.
    09-19-2021 11:36 PM
  9. bandofbrothers2112's Avatar
    To be honest I've not used split screen that way either too !
    mustang7757 likes this.
    09-20-2021 12:48 AM
  10. mustang7757's Avatar
    Guess everyone has there way
    09-20-2021 12:50 AM
  11. TMavC5's Avatar
    Normally and ideally, people don't do that. One video and other just to browse the web
    09-20-2021 07:25 AM
  12. bkdodger2's Avatar
    When I've tested video on two screens the one split app I hit is the one that sounds... Other one stops I've not seen any way to keep two running..
    09-20-2021 08:16 AM
  13. KupKrazy's Avatar
    This is not uncommon to happen. I have had TikTok on one panel and then Instagram on another - and then Instagram will have a video that auto plays and now you have two videos playing simultaneously. The only way I've seen to mute one side is to mute the audio in the app. Have you tried to tap on the video to see if there are volume controls that you can must for that video? Otherwise, I don't think there are other controls other than the physical volume that would turn all volume down.
    09-20-2021 11:22 AM
  14. missionsparta's Avatar
    Yes. A few have audio controls or a !it's button but many don't, and that's when the issue comes.
    09-20-2021 10:39 PM
  1. How do I take smart news off of my lock screen?
    Last Post: 05-01-2022, 06:32 AM
  2. Share your Cover screen GIFs thread.
    By bkdodger2 in forum Samsung Galaxy Z Flip 3
    Last Post: 10-24-2021, 10:30 PM
  3. How can I have only my fingerprint for my lock screen?
    By Azoor Salahudeen in forum Ask a Question
    Last Post: 09-20-2021, 07:15 PM
  4. LG Zone 4 Screen Pinout
    Last Post: 09-19-2021, 01:38 AM
  5. Replies: 5
    Last Post: 09-18-2021, 12:34 PM
