1. donebrasko's Avatar
    Has anyone figured out how much the battery is affected if AOD is always on?
    Thanks
    10-03-2022 01:53 AM
  2. SpookDroid's Avatar
    This has been discussed ad-nauseaum, but the answer is still pretty much the same: it's around 1 to 2 percent a day on 'big battery' flagships or the front screen on flips, and 3% on flip's full screen IF you don't action the notifications or keep tapping on the screen to wake it up/increase brightness. Since all these are OLED screens, power is very efficient on these tiny elements since most of the screen is effectively turned off.
    Most of the time this 'loss' of power is pretty much offset by how much it saves you from actually turning on the screen to check on notifications (that is, again, unless you do power on the screen every time you get a notification anyway).
    10-03-2022 01:06 PM
  3. Rhyalus's Avatar
    Try single tap to show always on, double tap to wake (or kill zombies).
    Saves power and works great.
    Agree about 1% per hour.
    R
    10-04-2022 10:39 PM
  1. How do I change the giant clock on the lock screen?
    Last Post: 10-02-2022, 09:52 PM
  2. Turn off ringer but leave but leave notifications on?
    By mizzn44 in forum Ask a Question
    Last Post: 10-02-2022, 07:02 PM
  3. I can't find Google assistant's ambient mode on my new Oppo phone
    Last Post: 10-02-2022, 06:24 PM
  4. Why i can't save new contact on my z flip 3 phone ?
    Last Post: 10-02-2022, 06:10 PM
  5. Why wont my emojis show up when i send a message on my moto e
    Last Post: 10-02-2022, 09:24 AM
