What's the best way to save battery life? Do you all keep Bluetooth on all day or only while you drive? Just wanna see what others are doing.
Thanks
Thanks
I'm getting an average of 4 days out of my watch. My setting s at set at vibrate for sound. 2 for brightness. Black background. And I routinely use the voice on with a double press and emails and texting regularly
Motion sensor is a huge battery killer. We need some kind of quick settings button. I think it was promised to be available at launch. Ability to quickly turn sleep monitoring on and turn watch-on from motion off, for example.
Thanks
I quicker way to do this would be great. I change this setting every night and then in the morning but going into the phone app is quite cumbersome.
Update. ... I've recently changed from the motion sensor of waking up the clock to the button only feature and didn't change anything else, and now I'm getting at least 13 and half hours and have 91% battery left. I will keep monitoring it and report back soon after its been a full day or longer.
Update #2... 37 hours later, settings the same and have 75% battery left on watch.
Update #3... Currently is been 64 hours now from one charge and my battery is at 49%. I haven't changed any settings and I've answered more calls today than I have in the last few days on it. So far. .. I'm very impressed with the battery life on this watch.
Update #4... As of this writing, it's been 108 and half hours on one charge and I currently have 27% battery still left.
Update #5... I ended up getting 120 hours out of my watch, till I got the message at 15% left, stating that it needed to be plugged in for charging. I didn't run the battery any lower because I don't know if it drains quicker or not beyond that point. Also I wouldn't have been able to charge it if it drain quick because I want around a charging source at the moment.
Conclusion. ... Anyone should should easily get the specified 3 days on a full charge, no questions asked. I will stick with my 4 to 5 days depending on how I use mine. For the most part I do use the heart rate monitor, I make and receive calls, I send and receive texts. I receive emails and the appy alerts along with news Republic and requallable notices. And set the display to 2 during the day as it's plenty bright for outdoors and 1 for night and button on only to view the clock with the black background.
Do I turn what off at night? I don't turn anything off on the watch. I get notifications all through the night but don't check them till morning. I have the watch screen set to timeout in 30 seconds. Other than that that's it. I also loaded Reqallable and have that check my emails and all other notifications, and the bluetooth stays connected to my phone 24 x 7 as long as is in range.
Sent from my SCH-I605 using Tapatalk
By chance, are any of you using Watch Styler for various custom watch faces? I seemed to notice a serious drop in battery life right around the same time that the app came out...unfortunately, I am hooked on the custom faces since using them on my Gear 1. So I'm not sure if I will make any changes, but just curious if the app is the reason for the variance.
