I don't know really Could be ... Gear support 2 communication methods Bluethooth and IR LED .. so if your TV has IR LED support then this could be possible
How about the ability to set multiple alarms throughout the day. I can't take my phone into work. A calculator would be nice also.
what about standalone "folder audio player" suitable for audio books and albums with more features?
if you like it - press Thanks... I will create it if many people request it
Awesome. That is very generous of you and I certainly do appreciate it.Multiple Alarm clock is my first app. Wish me luck. I hope it will be available next week
You will get it for free
Multiple countdown / kitchen multiple timer is my next to-do app
Thinking about 3 or 4 countdowns..
ask me for some features here.. I will try to do if possible
timer range
vibration
sounds
basic UI
etc
timer range
vibration
sounds
basic UI
etc
Can we have a brighter flashlight than the one that's in Samsungs app store?
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
1; Smartphone Camera viewer and Remote shutter, both still shots and video would be nice.
2; Application keyboard extension such as for Chat type apps.
3; Game sensor or simulation apps in addition to ones on Smartphone, for example, if when playing a Game on Phone the sensors on Neo smartwatch can be used in addition to add to realism and better control.
4; Diabetic Health apps of many such as reminders to take insulin, check blood sugars, and inclusion of health stats as BPM and HBM or?? the sky's the limit on this one! and large audience ready and interested, even "Insulin Pump" communications with Neo smartwatch is possible as BT is built into some "Insulin Pumps"
5; Child Distance Alert smartwatch warning app with the addition of "BT-Child Module" and BT Pairing with Smartphone to go off when signal is lost or reaches certain limit the user can set? 1M, 5M or 10M? and option for more than one "BT-Child Module" .
6; Remote Projector controls or HDMI device such as Chromecast?
7; other feature that are on traditional digital watches such as altimeter, GPS coordinates, compass or heading indicators.
8; BT Automotive communication functions, such as Key entry, trunk release etc, OBD viewer?
9; BT smartgear controls like Smart-LED bulbs, and AC control switches (on-off)
This is just off the top of my head, I made a list years ago that I will look at and see if I can add more items.
10; Photo light sensor app to be used by SLR Photographers? or other Light sensing apps as an accessory to other things?
Strobe?I am considering a better flashlight app as my next to-do app. If you have any special ideas for the app, it is now the time to write them down
