To pair to the gear 2, you will need to disconnect or un-pair the neo. Once connected to the Gear 2, going into Gear Manager, Samsung Apps, you can download watch styler, toggles, etc via your account officially, which will allow integration into gear manager. Then, go into settings in gear manager while still paired to the gear 2 and create a backup.
The key is to load that backup to your neo. For this to happen, you need to reset your neo while it's disconnected. Then, go into bluetooth settings and unpair the gear 2. Go back into gear manager and find your neo via scanning...pair it. It will set it up new, but you will have the option to restore via backup, the same backup that was created for the gear 2. Once restored, watch styler will remain in the home screen styler clock tab and watch styler on your phone will sync as it should. I did this with my galaxy s5 and neo as a work-around until they release a fix . Feel free to pm me for exact step by step. Good luck! You can then setup your watch the way you had it and reinstall previous apps by going into Gear Manager...Samsung Apps...three dot settings in upper right, then clicking purchased. If Purchased doesn't appear, go into Samsung Apps on the phone first, settings, purchased, then back into gear manager, samsung apps, etc. Weird, I know lol
