1. Primetimeplaya's Avatar
    I'm not interested in listening to music through the watch. This was pretty simple on my Pebble.
    05-07-2014 09:07 PM
  2. lizardchest's Avatar
    Not quite clear what you're asking for, as you say in the title you want the watch to control your phone, and in your post you say you want to listen through the watch. Two different goals, two different apps.
    Media controller on the gear controls the media playing on your phone.
    Music player plays music that you have loaded onto the internal memory of the watch.
    05-07-2014 09:13 PM
  3. Primetimeplaya's Avatar
    I want the watch to allow me to change the volume and title of the music i'm listening to through my phone. So I won't have to touch my phone to change what song i'm listening to or how loud the volume might be.
    05-07-2014 09:28 PM
  4. jrog28's Avatar
    Like he said, media controller app will do what you want.
    05-07-2014 09:32 PM
  5. Primetimeplaya's Avatar
    Thanks, got it to work. i wasn't realizing that I needed to use the media player for what I wanted to do.
    05-07-2014 09:33 PM
  6. MRBULLRED's Avatar
    I can't find an app called media controller? I have a gear 2 neo. Help please.
    05-08-2014 06:28 PM
  7. lizardchest's Avatar
    Even when you select the "apps" icon on the gear? Looks like four squares...
    05-08-2014 06:39 PM
  8. MRBULLRED's Avatar
    Yes sir. No where to be found.
    Media controller missing:
    05-08-2014 06:47 PM
  9. lizardchest's Avatar
    Everything up to the most current version? No one has mentioned missing stock apps on this forum before.
    05-08-2014 07:07 PM
  10. MRBULLRED's Avatar
    Model number SM-R381
    Software version:R381XXU0BND8
    05-08-2014 07:15 PM
  11. lizardchest's Avatar
    What apps show up on the watch? Also, what apps show up in Gear Managenr on your phone?
    Edit: just saw the video
    05-08-2014 07:20 PM
  12. MRBULLRED's Avatar
    Sent from my SCH-I605 using Tapatalk
    05-08-2014 07:23 PM
  13. lizardchest's Avatar
    Sorry, it was unclear if you pressed the apps icon in ithe video. Did you? There are more apps in there
    Edit: you know what you're doing. Don't mean to offend with my questions. What version gear manager?
    MRBULLRED likes this.
    05-08-2014 07:24 PM
  14. MRBULLRED's Avatar
    Yes, sorry.
    05-08-2014 07:25 PM
  15. MRBULLRED's Avatar
    Yes sorry.
    05-08-2014 07:29 PM
  16. MRBULLRED's Avatar
    Just did a factory reset on the watch and now all is well.
    lizardchest likes this.
    05-08-2014 07:53 PM
  17. lizardchest's Avatar
    From now on, that's my go to advice. Lol
    05-08-2014 08:05 PM
  18. Harshad Vyas's Avatar
    11-02-2014 04:39 AM
  1. Cannot get email notifications turned off
    By shining74 in forum Samsung Galaxy S5
    Last Post: 10-30-2015, 03:01 PM
  2. Looking for a great Calendar app to use!
    By badwolf_12 in forum Android Apps
    Last Post: 05-21-2014, 12:06 PM
  3. Replies: 11
    Last Post: 05-11-2014, 06:46 PM
  4. slideshow app which using Google play music?
    By Pixiuser in forum Samsung Galaxy S5
    Last Post: 05-07-2014, 09:27 PM
  5. Backup or Sync to sftp and Flickr
    By chocolateyum in forum Software Development and Hacking
    Last Post: 05-07-2014, 08:45 PM
