G Gega1234 Active member May 3, 2014 27 0 0 Visit site Jul 13, 2014 #1 Hello How to turn off sound of camera? Posted via Android Central App
S Sammuel1973 Well-known member Nov 24, 2013 990 3 18 Visit site Jul 13, 2014 #2 On your G2, go to Camera, Options, Sound and Shot, select Off. Sent from my SM-G900T using AC Forums mobile app
1812dave Well-known member Sep 9, 2010 3,133 35 0 Visit site Jul 13, 2014 #3 Sammuel1973 said: On your G2, go to Camera, Options, Sound and Shot, select Off. Sent from my SM-G900T using AC Forums mobile app Click to expand... wrong. sound and shot is for attaching sound to a picture. it's not for turning on/off the shutter sound. You can't turn off the shutter sound.
Hielko Well-known member Apr 14, 2014 50 0 6 Visit site Jul 13, 2014 #4 You can do this only by rooting your device and removing some sound files or by a hardware change that disables the speaker completely. Both ways are described elsewhere (see xda forum). Posted via Android Central App
S Sammuel1973 Well-known member Nov 24, 2013 990 3 18 Visit site Jul 13, 2014 #5 Oops, thanks. I misunderstood. Sent from my SM-G900T using AC Forums mobile app
1812dave Well-known member Sep 9, 2010 3,133 35 0 Visit site Jul 13, 2014 #6 Sammuel1973 said: Oops, thanks. I misunderstood. Sent from my SM-G900T using AC Forums mobile app Click to expand... I do that all the time. I either skim or simply don't get on the same wavelength as the writer.
