03-26-2015 09:36 PM
71 123
tools
  1. Micael Ackhammar's Avatar
    I had to stop using the app. Very inconsistent. Yesterday, I got mostly all of my app notifications, today none. I would get emails, and texts and no notifications on the gear 2. Can't continue until the app is working consistently. Going back to notify gear. Much better reliability.
    Is it possible to answer on whatsapp or gmail messages from notify gear?
    10-13-2014 01:28 PM
  2. gdanonym's Avatar
    Nope.
    And when you press a little bit too long, it will delete all messages. So also not perfect.
    10-14-2014 02:35 AM
  3. Micael Ackhammar's Avatar
    Ok. Im using Noti Wear it works good for me. Little more stable eould be good though
    10-14-2014 02:37 AM
  4. pstellato73's Avatar
    No. It does not have the ability to respond to any messages, but it's much more reliable to get notifications which is what I really need. If it had respond capabilities it would be great, but I really just want notifications at this point.
    10-14-2014 08:19 AM
  5. pacosal's Avatar
    Version 1.6.0 send to certification process:
    - More stable
    - Option to read default email app notifications
    - Option to reply messages by voice
    Recognition language is the one you have set in your mobile device.
    Micael Ackhammar likes this.
    10-15-2014 02:24 PM
  6. Michael Lynady's Avatar
    Now notifier is a good option
    10-15-2014 07:56 PM
  7. gdanonym's Avatar
    Not even close!!!
    Only very little text is shown and the font size is way to large.
    10-16-2014 02:32 AM
  8. Micael Ackhammar's Avatar
    The last update 1,5 has made my app to freeze and the touch not working! Strange no problem from the beginning but now!
    And sometimes the app wont launch when I push the icon.
    10-17-2014 04:18 AM
  9. pacosal's Avatar
    Version 1.6.0 CANCELED!
    Version 1.7.0 uploaded to certification process with more improvements.
    - Button to send whatsapp to previous contacts without reply.
    10-17-2014 01:47 PM
  10. warkittens26's Avatar
    How long do you think it will take to certify and be available on Samsung Gear Apps Market?
    10-20-2014 09:34 PM
  11. pacosal's Avatar
    usually 1 week!
    warkittens26 likes this.
    10-21-2014 01:28 AM
  12. gdanonym's Avatar
    Well, i'am moving away from the Gear 2. And have got a Pebble.
    From the moment i bought the Gear 2, i still was looking at youtube videos about the pebble and other smartwatches.
    First i bought the pebble, because of the better screen visibility outside and to have buttons. Yes buttons, because i was coming to a stage that i even want to turn a ebook-page from my watch. And for this buttons is more usable without looking at the screen.
    So i tried it and played with it. And found the right 2 apps with the perfect Tasker integration to do it ALL.
    Because i'm a very heavy Tasker user, this is so much better. And program my own menu's and functions myself.
    My own notification center, repeatable alarms set according profiles, popups, tasks manager, watchface with detailed phone/tasker informations. And i'm not done, because the possibilities are so much more to do. Even a google maps directions assistant can be done with Tasker.
    10-22-2014 09:18 AM
  13. pacosal's Avatar
    Version 1.7.0 released!
    10-24-2014 07:43 AM
  14. warkittens26's Avatar
    It appears not to be working. Attached is a picture of your latest 1.7 rev. As can be seen, Your App asked to add chompSMS to the white list. When SMS/MMS message come in, my phone makes its typical notification noise. Then the watch lights up, shows the Notification Wear app, then shows "No Notifications". This is happening right now with gMail (it is checked in the settings) and chompSMS. It was working there for a bit on gMail, but now its not showing anything but the No Notifications when email or sms messages comes in.
    10-24-2014 08:05 PM
  15. pacosal's Avatar
Name:	2014-10-24 16.51.21.jpg
    Is the problem fixed!
    11-03-2014 12:49 PM
  16. pacosal's Avatar
    Next version will be Gear S compatible!
    11-10-2014 02:14 AM
  17. pacosal's Avatar
    New version released with small improvements.
    11-22-2014 01:46 AM
  18. bece4peeps's Avatar
    Hi, I just downloaded the app yesterday! First of all, its a great app.
    You've improved it a lot.
    i just want to make U a suggestion:
    Why dont you make possible to read whole conversations(or part of them) so it's easier not to need to use the smartphone, its enough with the smartwatch.
    I hope you will do it.
    PD: It's for my gear 2 neo
    12-27-2014 03:11 AM
  19. pacosal's Avatar
    Version 1.9.0 uploaded to certification process
    - Interface improvements
    - Some new small features
    Thanks
    01-22-2015 08:53 AM
  20. borisblack's Avatar
    Thanks
    I wonder if your app supports russian language in notifications & in voice replays? is the only way to download it is Gear Apps at gear manager? are u going to continue developing it, or 1.9.0 will be the final ver?
    01-28-2015 05:41 PM
  21. garyhesq1's Avatar
    I installed this tonight on my Note Edge and it does not function. I restarted both devices and made sure all boxes were checked. It totally ignores any notifications. Got any tips to get it working? I'd love to have these features.
    UPDATE: I missed one setting. Retesting now.
    03-26-2015 09:36 PM
71 123
  1. Status bar notifications area problem
    Last Post: 08-31-2014, 11:32 PM
  2. Gear 2 blood pressure
    By Gega1234 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 08-26-2014, 03:48 PM
  3. Problems with Notification bar on SPH L900 using LiquidSmooth 4.4.4 and Nova Launcher
    By bongolock in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 08-26-2014, 03:10 PM
  4. Replies: 4
    Last Post: 08-26-2014, 12:21 PM
