Originally Posted by
jwt873 I don't know why you wouldn't get the search function in the gear app screen..
One thing you might try... Tap on the blue bar between where it says 'select category' and the three vertical dots. You should get a side bar popping up from the left side of the screen. There you will be able to select 'Home'.. Try that.
I guess I do not have the same Gear Manager/Store that you do. That sucks frankly. Below are the step by step from Gear Manager home page to going into the store. I even uninstalled and reinstalled Gear Manager...
