Galaxy Note 10 Deal: BOGO at Verizon!
  1. chexx05's Avatar
    Any one else having battery issues after the recent update.? Not sure if it s the watch up date or the lollipop update on my note 3 that's causing it to drain so fast. I charged my watch over night and this morning took it off the charger and now after 6 hrs of use its dead. On a normal day I would get at least 2 days of full use before I had to charge it
    03-07-2015 02:31 PM
  2. NoFaQ's Avatar
    I'm noticing a more than usual battery use/drain, but nothing to that extent. Now, I have to charge every other day, instead of a three day charge..
    03-11-2015 09:49 AM
  3. leanneleg's Avatar
    Me too! I got slightly less than 24hrs on a charge when I would normally have gotten 2-3 days. As well, when I checked the battery app, bluetooth was the number one user.
    03-12-2015 09:17 AM
  4. kbboykin's Avatar
    Yes, battery drain is horrible after this update, but also horrible since the Lollipop update (Sprint, LP 5.0)
    03-12-2015 12:20 PM
  5. adl80l's Avatar
    I have the original Gear. After the update my battery life has dropped to 8hrs. I have reinstalled Gear manager and reset the watch to no avail.
    03-12-2015 12:47 PM
  6. chexx05's Avatar
    Glad to see I was not the only one with this issue. I hate carrying my charger with me back and forth to work
    03-12-2015 06:19 PM
  7. LowIQ's Avatar
    I'm not seeing any difference so far with my Galaxy Note 4 and Neo 2, I will do a Battery life log comparison, as I have been keeping one from each update, I will post after a week to be fair in the comparison.
    03-14-2015 08:43 AM
  8. chexx05's Avatar
    It only started doing it after the lollipop pop update on my. Note 3
    03-14-2015 11:31 PM
  9. LowIQ's Avatar
    After two days of running my Neo 2 is at 70% battery so I see no difference in battery usage, it might be a compatibility issue with Lollipop or?
    also after I do a Gear update I always shutdown the Neo 2 and Galaxy Note 4, to then restart the Note 4 first and after 5-10 minute in letting all things resolve out to then turn my Neo 2 on... for me it has worked out best in keeping both functioning efficiently. even when I do the Android app updates I do this as often in the past an update will rattle the Neo 2 in sometimes not working properly?... it is one thing that makes me envious of Apple iPhone users in when they get an update not so much drama is to be expected... but then again iPhones are a different animal altogether in not having the ability to customize to the users wishes, among many other things?, I guess all things have a price?
    03-16-2015 06:24 PM
  10. NoFaQ's Avatar
    I was having battery issues with the previous update, but this latest update has taken my Gear 2 Neo back to my normal battery usage.
    03-17-2015 09:58 AM
  11. adl80l's Avatar
    I just got another update a few minutes ago. Hopefully it resolves the problem.
    03-19-2015 12:58 PM
  12. chexx05's Avatar
    So I guess if your watch is rooted it will not update 😕
    03-19-2015 08:37 PM
  13. chexx05's Avatar
    Boo
    Attached Thumbnails Battery issues after recent update?-screenshot_2015-03-19-20-28-31-1.jpg
    03-19-2015 08:53 PM
  14. miamiray's Avatar
    My battery life used to be more than 24 hours on my Note 3 and 2 days on my gear 2 neo. After Lollipop it became about 5 hours on the note 3 and maybe 8 on the Neo. The note is now up to about 10 hour battery life (on light use), while the gear 2 is useless giving me about 5 hours life even with the watch set to not turn on when I twist my wrist. The update today did not help. My gear 2 neo is virtually useless, I am considering giving it up and looking into an android watch.
    03-20-2015 02:47 PM
  15. chexx05's Avatar
    My. Phone updated gear manager last night. charged it and tested it. Took it off the Charger at 930 this morning and got it down to 5% at 10pm so 12 and a half hours which is double the battery life from a week ago but still. Not what it used to be where a single charge would atheist get me a day and a half before having to charge it again
    03-22-2015 11:00 PM
  16. Michael Pelz's Avatar
    I'm having a similar issue. I use my gear2 for sleep tracking, just to get a general idea, and for just the time. I updated it two days ago and thought nothing of it, then, it died after a couple hours off the charger yesterday from a full charge, then died again overnight, and after 30 minutes it lost over 50%.
    If this is how Samsung does business I'm switching everything over.
    03-31-2015 01:24 PM
  17. bassartist's Avatar
    I am having the issues. 5-6 hrs and its gone.
    04-04-2015 07:04 PM
  18. Hielko's Avatar
    I suggest to do a complete reset of the watch, probably some process is running continuously after the update. On my Gear 2 I had no problems at all.
    04-06-2015 05:21 AM
  19. JamessAnderson's Avatar
    Yes, many people are having a same problem I do to. When I bought my Android phone I thought the battery life was amazing, but since kit Kat update my battery is horrible.
    04-06-2015 05:40 AM
  20. chexx05's Avatar
    Upgraded my phone to s6 edge and battery life improved I have not charged my watch since 830 yesterday morning and as of right now I'm at 28% so the lollipop update on some phones messed up the gear.
    04-18-2015 09:12 PM
  21. MerlinTheProgrammer's Avatar
    Replying to an old thread, but what the heck...
    My Gear 2 Neo (talking to Samsung S4) suddenly started losing charge
    very quickly. Use to go 3 or 4 days and suddenly went to hours only.
    Thinking about what changed recently, I went into the "Notifications"
    control on the Gear Manager, and disabled all but a very few apps
    from being able to send notifications to the watch. My battery usage
    is back to normal. I *think* it was "Voicemail", but it may also have
    been "Missed Calls".
    I figure I only really need Email/Gmail/IncomingCall/Messages/Schedule.
    02-27-2016 04:26 PM
  22. Totquil's Avatar
    Exactly the same with mine. S7 GEAR NEO Bboth up to date. Happened after the last gear update about 3 weeks ago. Dropped from nearly three days to less then one. Samsung have stuffed up but I keep getting the run around. I didn't change any settings so obviously the update did or stuffed up the blue tooth. I have reset check all apps I can control (not many) been into notifications found a few I didn't have turned on now set to notify so I turned them up. I still have bad battery life so buggered if I know
    04-14-2016 05:35 PM
  1. Replies: 2
    Last Post: 03-21-2015, 10:29 AM
  2. When samsung note 3 neo will get lollypop update
    Last Post: 03-13-2015, 07:36 AM
  3. Updating Contact Photos?
    By reid101mills in forum LG G3
    Last Post: 03-11-2015, 11:30 PM
  4. No notifications after hearing alert ringtone
    By Klovis 27 in forum Ask a Question
    Last Post: 03-08-2015, 07:02 AM
  5. Why is my LCD unresponsive after it times out?
    By AC Question in forum LG G3
    Last Post: 03-07-2015, 02:24 PM
