1. jordans0nly's Avatar
    Well, I tried and tried. Tried all the apk's, didnt work. Tried downloading Gear Manager on my father's S5. Worked that way. Copied it from his phone, used ES File Explorer, copied the app to Google Drive then downloaded it to my Nexus 6. The app loaded, would search, but never find it.
    Before I return it, any other way to get it to work, besides rooting? Which I dont really have any interest in.
    Thanks.
    07-29-2015 09:46 PM
  2. jordans0nly's Avatar
    Did bypass the Gear Manager part by tapping the Gear S watch icon, but when I clicked on notifications on the watch, would always say that the bluetooth wouldnt connect or their was a problem with it. Bummer.
    07-29-2015 10:35 PM
  3. NoFaQ's Avatar
    A quick google search yielded this:
    [GUIDE]NO ROOT / Easiest way to pair Gear 2 … | Samsung Gear 2 | XDA Forums
    You can't just put the Gear Manager on any phone. It's designed to only work with Samsung phones.
    07-30-2015 10:48 AM
  4. godzillinois's Avatar
    Thanks.
    You should return it as quickly as possible, none of the Samsung Gear line is compatible with any other phones besides Samsung ones. And even with Samsung it isn't compatible with all models, I'm not even sure they have a stable Root to make it work with other phones. I haven't checked myself.
    07-30-2015 02:54 PM
  5. jordans0nly's Avatar
    Traded my Nexus for a Note 4. Gear S in sight
    AXEL314, godzillinois and Talderon like this.
    08-01-2015 01:27 PM
  1. How can I get my S6 Edge out of demo mode so I can make calls?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 10-08-2015, 10:16 PM
  2. Stuck trying to clear cache partition...
    By GeodudeFFP in forum Motorola Droid Turbo
    Last Post: 08-02-2015, 02:10 PM
  3. Replies: 1
    Last Post: 07-29-2015, 10:36 PM
  4. Replies: 0
    Last Post: 07-29-2015, 09:29 PM
  5. Nexus 4 lollipop 5.0.1 update error
    Last Post: 07-29-2015, 09:20 PM
