1. Problacklist's Avatar
    I have the Galaxy Gear Fit Paired with Galaxy Note 3. if I select the Weather Clock Home screen it displays (Tap here to use location info on mobile device) ive tried everything but no luck maybe im missing something. how can i fix this problem
    04-13-2014 01:34 PM
  2. jian9007's Avatar
    You have to confirm it on your phone when it says tap here. You also need to have the stock Samsung weather widget on your phone. So if you're running a custom launcher or anything it won't work. Select the box to use your current location. The screen on your phone will look like this-
    pocassidy likes this.
    04-22-2014 05:39 AM
  1. Galaxy s3 no "Gear Manager" app in Samsung apps
    By lizardchest in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 07-23-2015, 08:57 AM
  2. Galaxy S5: Tempered glass screen protectors?
    By jonebk12 in forum Samsung Galaxy S5
    Last Post: 06-11-2015, 10:46 PM
  3. GS3 screen randomly freezes
    By Hamza Baloch in forum AT&T Galaxy S III
    Last Post: 06-02-2014, 12:02 PM
  4. how can signal suck this bad -96dbm at home
    By demarco5 in forum Samsung Galaxy S5
    Last Post: 04-14-2014, 10:08 AM
  5. Samsung galaxy note 2 upgrade issues to 64gb mp3 not recognized
    By GNARC in forum T-Mobile Galaxy Note 2
    Last Post: 04-13-2014, 11:17 AM
