1. Amir Hosseini1's Avatar
    Will Samsung gear fit works when the phone is off or not in range.
    I mean can only wear gear fit for running without having phone with me? Will it track the path I ran and sync it when gear fit is in phone range?!
    Thank you
    10-26-2014 11:20 AM
  2. foxbat121's Avatar
    Yes, I bought one for my wife and she didn't even have a Samsung phone. It works perfectly fine without tethering to a phone. I turn the battery off and it lasts a whole week. The fit keeps fitness history on itself. You only need to sync to phone when you need view on the phone. Otherwise, no phones needed.
    In fact, the health app on my GS3 is so pitful, half of the functions don't even work. It is beyond useless.
    10-27-2014 06:02 PM
  3. b0b77's Avatar
    So that means I dont need a phone at all to use the gear fir. And i do not have a phone.
    05-24-2016 04:28 AM
  4. rasmith1959's Avatar
    No, you do need a phone in order to get the apps onto the smart watch. It just doesn't have to be linked to the phone when you're out exercising.
    05-24-2016 04:39 AM
  5. rasmith1959's Avatar
    Just to add some additional info here, I just did a factory reset on my watch just because I wanted to be sure of a few things. First off when you buy a smart watch the first thing that happens after powering it on and it's finished booting is that it tells you to download the Android Wear app on your phone and then it proceeds to pair it. So any Android Wear device has to be paired with an Android device running the Android Wear app. Now the devices don't have to be from the same manufacturer, I have a Nexus 6 from Motorola, and a Samsung Gear Live Smart Watch.
    Once paired to a Android device it then proceeds to sync all wear enabled apps from your Android device to your watch. So I'm don't think that the watch even comes with any apps preinstalled and it only runs whatever is available from the device it's paired with.
    05-24-2016 04:57 AM
  6. b0b77's Avatar
    Does it work with a lg g3. or can i connect to my brothers m8 and disable whatever uses the phone
    05-24-2016 05:54 AM
  1. No phone call , no SMS since yesterday on my Galaxy S3 : HELP !
    By Robert L1 in forum Samsung Galaxy SIII I9300
    Last Post: 11-05-2014, 07:31 PM
  2. What a great phone!
    By dhc8guru in forum Moto X
    Last Post: 10-27-2014, 11:27 PM
  3. Quick Comparison - Note 4 pedometer vs gear 2
    By thegame161 in forum Samsung Galaxy Note 4
    Last Post: 10-26-2014, 05:03 PM
  4. Dead bugdroid displayed after update? Phone won't turn on. Please Help!
    By heather-amelia in forum General Help and How To
    Last Post: 10-26-2014, 01:32 PM
  5. Replies: 1
    Last Post: 10-26-2014, 11:09 AM
