1. jaxsta's Avatar
    I've just turned on my gear fit after a few months away and it is showing the time 30 minutes faster than it should be. It is cennected to my phone and all are up to date.
    Is anyone else having this problem?
    I'm running an S5
    01-06-2015 03:49 PM
  2. Yvonne S's Avatar
    Mine was doing the same. Went into the time and date settings on my galaxy S4 and the time zone was set to Lord Howe Island for some reason. Changed it back to the correct time zone and the gear fit updated to the correct time
    01-20-2015 04:47 PM
  3. SHW22's Avatar
    Thanks so much for that fix !! I had given up and was about to take it back to the store and tell them where they could keep it lol I'm not keen on not having it automatically updated by the satellite but if it makes the gear fit time correct (which it did!!) I'll live with it.
    This gearfit seems very much a 'beta' product and I can only hope they work towards fixing the bugs...
    02-16-2015 03:46 PM
  1. No sender name shows when receiving text message
    By cgr45 in forum Verizon Galaxy S III
    Last Post: 01-22-2015, 06:22 PM
  2. Replies: 1
    Last Post: 01-06-2015, 11:06 PM
  3. Replies: 4
    Last Post: 01-06-2015, 02:44 PM
  4. Replies: 1
    Last Post: 01-06-2015, 01:52 PM
  5. My galaxy s3 shows not registered on network, when sim is in. help??
    By aqeel abbas in forum General Help and How To
    Last Post: 01-06-2015, 01:28 PM
