1. AC Question's Avatar
    I have had this Gear Fit for a month and have been averaging three to four days between charging. Now a few days ago it started running out of charge by early afternoon- witht no changes in my setting or usage. I charge it to 100% in the a.m., but 6pm its dead. This has been this way for the last three days. Only difference I can think of is my note 4 did a lolipop OS udate last week, but the gear fit battery drain issues did not align with the data the update happened. Help please!
    04-16-2015 07:18 PM
  2. Nicole Jackson2's Avatar
    I'm having the exact same issue! I read on another board that the battery needs to be replaced but going through the instructions you have to dismantle the entire watch to do it. I don't see how you won't damage it by changing the battery 😡
    04-26-2015 01:06 PM
  3. AmyC76's Avatar
    Can you take it to a Samsung authorized dealer? Mine has started as well.
    04-26-2015 01:41 PM
  4. sunlitstar's Avatar
    Mine is doing the same and I've only had it since Christmas. Already had to send it back once for a fix. Getting very disappointed and frustrated. Any ideas?!
    04-29-2015 07:33 AM
  5. Sandy Gray's Avatar
    I received mine at Christmas as well, and have noticed a serious decrease in battery life the past few weeks. Anyone finding a solution other than replacing the six month old battery???
    05-07-2015 08:38 PM
  6. Jill Kight's Avatar
    I just got my Gear Fit2 4 days ago. Even with all connections turned off, I only get about 24 hours on a charge. And I put mine in power saving mode at night. Also, when I have BT connection turned on my Gear Fit2, my phone's battery drains faster as well.
    08-11-2016 11:18 AM
  7. BekiInd's Avatar
    If you have not had it long - take it back. Mine is almost worthless after a year - battery only lasts about 7 hours. And the info I get from it is not all that useful, since if I pause, it quits recording without me knowing it.
    08-30-2016 08:10 AM
  1. Gear S battery issue
    By hichem jerbi in forum Samsung Gear S
    Last Post: 11-01-2016, 07:37 PM
  2. Howdy any Gear Fit users use a Nexus 6 ?
    By SaltyBrine in forum Google Nexus 6
    Last Post: 12-01-2015, 08:22 PM
  3. Replies: 13
    Last Post: 06-26-2015, 03:12 PM
  4. Replies: 2
    Last Post: 04-17-2015, 11:17 PM
  5. Is the Verizon S6 still global?
    By Gav508 in forum Samsung Galaxy S6
    Last Post: 04-16-2015, 09:34 PM
