A AC Question Dec 20, 2015 #1 Has anyone found a way to make the galaxy note 5 compatible with the gear fit? The note 5 is not listed as a compatible device.
D darksngel119 Active member Nov 11, 2015 25 0 0 Visit site Dec 20, 2015 #2 Re: Has anyone found a way to make the galaxy note 5 compatible with the gear fit? The note 5 is compatible the list of devices are those that are NOT compatible. https://forums.androidcentral.com/e...t%2Fgear%2Fgear-fit-support%2F&token=iagep8pW Posted via the Android Central App
