Can I damage Fit2 by charging it using the "Fast Charging" charger that came with my Note 5 or 7?
badkitties
880
Can I damage the Fit2 by charging it using the "Fast Charging" charger
that came with my Note 5 or Note 7?
I know those chargers only fast charge with compatible phones like my
Note 5 or Note 7, but what if the charger goes haywire and charges the
Fit2 with too much juice?(much higher voltage)
Thanks!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,283
4,390
113
Re: Can I damage Fit2 by charging it using the "Fast Charging" charger that came with my Note 5 or 7
It shouldn't be a problem. Devices draw current--the chargers don't push current into the device. So the device will only draw the current it needs. I routinely use the quick charger from my ASUS Zenfone 2 on all kinds of devices.
billykac
1,339
^^This^^
Devices draw what they need. I am using my OEM charger for the Fit 2 and it works perfectly. I'd expect the same from the 3rd party wall warts as well.
badkitties
880
^^This^^
third party chargers? I've always been afraid of them
because I heard some of them output 1.21 gigawatts.
billykac
1,339
Only when you wire your Flux Capacitor in series with the power supply. :)
badkitties
880
I was always amused by that flux capacitor charger because it has two outputs... 1A and 2.1A... (like 1 and 21, as in 1.21 gigawatts) yes, I know that must make me sound like a dork(guilty as charged) :)
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,283
4,390
113
Whoa, this is heavy.:p
toenail_flicker
4,677
I never use third party unless they have proven safe. I have several well-made charging plates that are third party, but have been used safely for years. Same with my TYLT. Does a great job and turns off after charging. All my wireless plates do. As for cables - not so much. I use Sammy's or Ammy's without fail. No third party for me.
Chelrie
