1. gmillas's Avatar
    I own the following devices.
    Xiaomi RedMi Note 3 Pro
    android 5.1.1LMY47V
    MIUI 7.5.1.1
    Gear Fit2 SM-R360
    software R360XXU1BPG3eChO
    I installed the
    Gear 2.2.16101261
    Gear Fit2 Plugin 2.2.04.16111741N
    Samsung accessory service 3.1.26_161116
    I perform the pairing proccess from gear app where it normally sees the request and then the gear (app from mobile) is closed without any message and gear fit2 stays on screen writing "setting up" where nothing else happening and at the end sent message that "the setting has lasted more than expected. Do you want to try again; "
    For the above issue I have tried the following:
    1)
    Remove all Samsung app's
    cache cleaning
    Factory reset gear fit2
    Reinstalling app's
    2)
    cache cleaning
    Reinstalling previous versions
    Please HELP
    01-23-2017 06:51 AM
  2. djurkash's Avatar
    Have you tried connecting it to Samsung phone?
    01-23-2017 09:53 AM
  3. gmillas's Avatar
    Yes it connected right away. Samsung A5
    01-27-2017 04:44 AM
  4. djurkash's Avatar
    I can not really think anything else but to try factory reset phone itself...I am using GF2 with my MiMax on Miui 8.0.1.3 without any issues
    01-27-2017 02:10 PM
  1. Samsung officially announces the cause of the Note 7's battery fires
    By D13H4RD2L1V3 in forum Samsung Galaxy Note 7
    Last Post: 02-08-2017, 06:40 AM
  2. mx player pro not opening help?
    By jaqueline808 in forum General Help and How To
    Last Post: 01-23-2017, 10:41 AM
  3. Replies: 1
    Last Post: 01-23-2017, 06:21 AM
  4. Why my moto e can't connected to pc?
    Last Post: 01-22-2017, 10:36 PM
  5. Replies: 0
    Last Post: 01-22-2017, 04:23 PM
