1. Liam1694u's Avatar
    I've had my Gear Fit2 for about 8 months now. I have it streamlined to extend battery as much as possible, but there is one feature I use all the time that is an enormous battery hog. The Stopwatch.
    And it makes no sense to me. There is a clock running 24/7 on the thing. I don't understand why using the stopwatch (with the screen off, except to start and stop) would suck up battery. And I'm not talking about a little heavier than expected drain. The stopwatch can suck the battery completely dry in a matter of just a few hours. Which has happened when I forget to turn it off. Just look at this random screenshot I took a few minutes ago. My battery is halfway gone, and almost all of it is from the stopwatch.
    Anybody else seen this problem or know of a fix? I've updated my firmware/software several times and have done factory resets. No help.
    Attached Thumbnails Fit2 Stopwatch App Battery Hog help-screenshot_2017-06-20-07-43-56.jpg
    06-20-2017 08:10 AM
  1. note pro 12.2 and battery
    By andyhamish in forum Samsung Galaxy Note Pro 12.2
    Last Post: 06-28-2017, 07:23 PM
  2. Replies: 1
    Last Post: 06-20-2017, 12:58 PM
  3. Why is my battery draining?
    By Harkamalsingh in forum Ask a Question
    Last Post: 06-20-2017, 12:42 PM
  4. Samsung Dexm make app go full screen
    By Dima Medvedev in forum Samsung Galaxy S8 & S8+
    Last Post: 06-20-2017, 06:05 AM
  5. Replies: 1
    Last Post: 06-20-2017, 04:37 AM
