• 2
    Turning screen on on Gear Fit 2 Pro
  • 1
    Moved:
    Samsung gear fit 2 rm 220
  • 1
    Gear Fit 2 Pro swim interval guide?
  • 1
    Gear Fit 2 pro battery life seems poor.
  • 1
    Remove exercises you don't do?
  • 2
    How to easily find battery level?
  • 1
    Fit 2 Pro BT conflict with phone
  • 10
    Gear Fit2 Pro Swim Counting
  • 1
    Strava discrepancy (Moving and elapsed time)
  • 1
    Moved:
    Gear Fit2 Exercise countdown
  • 2
    No new message vibrations
  • 4
    Icon on the top right corner
  • 1
    Samsung Gear Fit 2 Pro Notification ! !
  • 1
    New to Fit2Pro
  • Page 1 of 3 123
    Thread Display Options
    Use this control to limit the display of threads to those newer than the specified time frame.
    Allows you to choose the data by which the thread list will be sorted.
    Order threads in...
    Note: when sorting by date, 'descending order' will show the newest results first.
