1. MsBlingberry's Avatar
    My gear fit 2 pro sensors stopped working a month ago. No steps recorded, no HR monitor. It doesn't track anything except time. It's basically useless now. I've tried factory reset, still nothing. Please help!
    01-15-2019 12:10 PM
  2. B. Diddy's Avatar
    I moved this to the Gear Fit 2 Pro forum for more specific traffic.
    01-15-2019 03:08 PM
  3. darksirhenry's Avatar
    You are out of luck! my gear fit 2 pro also stopped tracking steps, heart rate, turning on with wrist movements...I sent it in to samsung (4months used) under warranty and was told the problem is due to "liquid Damage".. I never even had a chance to expose it to water or rain or anything!
    anyway many people are reporting the same...many have noted it happened after an update...i dont know..however we are out of luck for any help from samsung!
    01-24-2019 07:45 AM
  1. How to create device tree from scratch without help of other devices?
    Last Post: 01-16-2019, 02:08 PM
  2. my tecno spark screen has stopped totally.
    Last Post: 01-15-2019, 09:59 PM
  3. I need to install Oreo 8 on my Samsung a530f
    By Scotty Beam in forum Legacy Android & Other OS's
    Last Post: 01-15-2019, 03:11 PM
  4. What place buy Samsung smart watches
    Last Post: 01-15-2019, 03:09 PM
  5. Solusi signal samsung grand neo plus
    Last Post: 01-15-2019, 03:07 PM
