1. rellim's Avatar
    OK guys...more Samsung pre-release homework for you!
    Sammuel1973 and Dante314 like this.
    11-04-2014 01:24 PM
  2. reesh11's Avatar
    Very interesting. So in essence we must choose a device to make calls and texts from.
    From my smokin' hot Note 4
    11-04-2014 02:33 PM
  3. aitt's Avatar
    It still didn't directly answer the question of needing another number or not
    11-04-2014 03:17 PM
  4. dov1978's Avatar
    I'm sure to make and receive calls independently with the Gear S you need a separate sim/number. If you're using a secondary sim attached to your existing phone call plan/number you can only make out going calls from the Gear S and not receive them.
    sent from my Galaxy s5
    11-05-2014 08:06 AM
  5. Sammuel1973's Avatar
    Thanks, you may be right. As shown in the video, when you make a call from the watch, you select the watch option, as opposed to the phone option, but somehow the number of the phone (original number, not the 2nd number) shows up on the recipient's end. As for incoming calls to the watch, these calls are forwarded to the watch from the phone. Can someone confirm my understanding? Thanks.
    11-05-2014 09:41 AM
  6. Tikerz's Avatar
    I just got mine.
    Incoming calls to you phone can be forwarded to the Gear. The Gear does have it's own number so if you make calls from the Gear when you're away from your phone, it will use the Gear phone number. Same goes for texting from the Gear while you're away from your phone.
    Mom2Ninjas likes this.
    11-06-2014 02:10 PM
  7. Sammuel1973's Avatar
    I just got mine.
    Thanks, so just to confirm, which phone number shows up on the recipient's end?
    11-06-2014 02:12 PM
  8. Tikerz's Avatar
    If you're away from your phone, meaning NOT in BT range, it will show the Gear number when you call someone.
    11-06-2014 02:19 PM
  9. Sammuel1973's Avatar
    Oh well, I was hoping the original (smartphone) number shows up on recipient's end instead. So it seems we will have to give out our 2nd number to friends, family, etc. so they would know the calls come from us.
    11-06-2014 02:29 PM
  10. Tikerz's Avatar
    Yeah, unfortunately.
    11-06-2014 02:33 PM
  1. Does your Note 4 have an antenna on the lower right side?
    By dpham00 in forum Samsung Galaxy Note 4
    Last Post: 11-05-2014, 07:43 AM
  2. not registered on network message
    Last Post: 11-05-2014, 02:49 AM
  3. Unlocked Moto X - How do I do it?
    By tech_fan in forum Moto X (2014)
    Last Post: 11-04-2014, 11:26 PM
  4. Replies: 0
    Last Post: 11-04-2014, 01:15 PM
  5. Alcatel OneTouch, need to unroot it. Help?
    Last Post: 11-04-2014, 01:11 PM
