Michael Maloney1
not to ask a dumb ? but they were able to activate it? they were nto able to this morning. they said verizon had a network wide issue with it. let meknow ty
Yep. Just exchanged it.Still like that after charging overnight?
I'm hoping to get mine next week but can anyone tell me if I'll get WhatsApp notifications on the Gear S? I'm not all that familiar with Tizen yet
sent from my Galaxy s5
Yes, there three different connection modes for the watch:If the watch is connected to the phone can I make calls with the watch without having any plan for the watch? Anyone know?
Thanks you are awesome! Currently debating whether to wait and get tmobile version or att today. I'm not really looking for a smartwatch with plan anyways, just connected to the phone like pebble or moto 360Yes, there three different connection modes for the watch:
1. BT connection
2. Remote connection when you can't connect to the phone via BT. The Gear S will try to connect via wifi or cell network.
3. Gear only. When it is not possible to connect to the phone in any of above mode.
When you are in BT connection, you can make/receive phone calls and SMSs via the phone itself. The watch's mobile connection or number is never used.
When you are in other two modes, you will rely on watch's own cell radio for phone calls and SMS. Hence a plan is required. But if you don't care about phone calls or SMS, you don't have to use mobile radio. You can still use the wifi connection to connect to your phone for other watch functions.
When you are in Gear Only mode, apps no longer work on the watch.
1. BT connection
Not even Tizen apps downloaded directly to the Gear S? I was hoping to be able to leave my phone at home when I go running, and to use GPS and the phone apps to listen to audiobooks and map/track my runs.When you are in Gear Only mode, apps no longer work on the watch.
You have to download it. First setup requires the app on the phone too. After that stand alone mode works.Is Nike+ available already or is it preinstalled in your Gear S? Do you get continuous heart rate monitoring in your workouts? Gear Fit's heart rate monitor was a flop on this area.
