1. space6333's Avatar
    When Gear S is on Bluetooth to Note 4, does it receive notification for incoming Viber or Whatsapp messages
    Will Gear S on Bluetooth to Note 4 work for Skype calls/video calls ?
    I mean when NOT using the phone line of Gear S.
    Thank you.
    Elie Nammour likes this.
    11-07-2014 01:58 PM
  2. aitt's Avatar
    Sorry can't answer any of those as I don't use any of them. I would suspect that the app would have to be updated to support Gear, otherwise you would just get the notifications.
    11-07-2014 02:09 PM
  3. srikanth sanagapalli's Avatar
    Yes. We can definately see messages from whats app, viber, FB messenger...
    But unfortunately we cannot reply from watch... I am using it from last 3 days. only missing reply feature from whats app/viber etc...
    11-17-2014 03:43 PM
  4. Amit Oberoi's Avatar
    Yes U can reply, u will have to install the app Notifications for gear s from the play store. I have been using it in the same setup as the op and it works pretty decently.
    11-20-2014 08:29 AM
  5. ryan lee6's Avatar
    So u can reply to whatsapp from the gear s then wicked thanks
    12-17-2014 04:57 PM
  1. Would you be giving friends your new Gear S number?
    By Sammuel1973 in forum Samsung Gear S
    Last Post: 11-08-2014, 08:38 AM
  2. Replies: 1
    Last Post: 11-07-2014, 03:03 PM
  3. Replies: 2
    Last Post: 11-07-2014, 02:52 PM
  4. Replies: 0
    Last Post: 11-07-2014, 01:53 PM
  5. Replies: 0
    Last Post: 11-07-2014, 01:46 PM
