11-01-2016 10:29 PM
42 12
tools
  1. karsdroid's Avatar
    so i find the watch part of the watch disappointing if i can't move my wrist and have the screen come on like the original gear.....if i wanted just a black background with white numbers i would choose that as a watch face. the watch faces you can set don't make sense to me if i only see them when i push the button. am i missing a way to "in effect" bypass the "lock screen" (black screen with white numbers that pops up when i move the gear)? this may indeed be a deal breaker for me....
    11-09-2014 11:22 AM
  2. foxbat121's Avatar
    It is called 'Motion' and is on by default. You might accidentally disabled it.
    11-09-2014 02:36 PM
  3. jspring86's Avatar
    I think the OP is referring to the fact that when you raise your wrist you only see a black and white clock on the Gear S:
    is there a setting to see full watch face with turn of the wrist like original gear?-2014-11-09-13.49.00.jpg
    He wants to see his actual watch face when he flicks up his wrist like this:
    is there a setting to see full watch face with turn of the wrist like original gear?-2014-11-09-13.49.13.jpg
    I also cannot seem to figure out how to make that happen. Turning motion on just gives you the black and white clock and not the watch face you actually selected.
    11-09-2014 02:51 PM
  4. foxbat121's Avatar
    I see. It's probably a power saving feature. Turn on full power often by the motion gesture will shorten the battery life significantly. I found touch the screen will make it turn into full watch face. I personally always turn it off to save as much better as possible.
    67srbell likes this.
    11-09-2014 03:10 PM
  5. ougum1's Avatar
    That's strange. I keep "wake up gesture" off to conserve battery too, but when I turn it on and flick my wrist, I get my full watch face every time.
    11-09-2014 03:36 PM
  6. sux2bu's Avatar
    Check your settings, there must be something making it do that. Mine always comes on to the full face.
    11-09-2014 04:23 PM
  7. koalabear's Avatar
    What you see when you raise your hand is totally dependent on which watch face your choose. If you use the stock blue face when you raise your wrist you'll get the background dimmed but hands bright. Touch the screen and the whole thing is bright. Other faces (that use digital numbers) will just light up the time when you raise your wrist and if you touch the screen you get the full face (like the one with weather, notifictions etc) Great trick to save power!
    11-09-2014 04:24 PM
  8. karsdroid's Avatar
    yes, exactly.....i'm not a fan of the blue stock face and it is the only one that comes on with a flick of the wrist, though dim. i don't really care about power saving i just want to see the watch face when i move my wrist, like my original gear. it should be an option. there is the watch always on option, but that is a gratuitous waste of battery power... i love the screen, if the watch face doesn't come on when i flick my wrist, just the black and white icons, the screen is being wasted. i'm disappointed by a few things on the s.....
    11-09-2014 05:26 PM
  9. foxbat121's Avatar
    Any of the stock watch face supports this feature.
    The dimness for power saving is probably important enough for Samsung to enforce as the AMOLED screen is very power hungry. If not implemented this way, most ppl will have watch face come on full blast many many times a day and the battery will probably dead by noon
    11-09-2014 05:39 PM
  10. karsdroid's Avatar
    no, most of the stock just show white numbers on a black background.....once again, should be a choice i can make. as much as i like the screen the few irritating things i've run into are going to send me back to verizon to return it.
    11-09-2014 05:47 PM
  11. jspring86's Avatar
    I'm sure it is for saving battery, its not a deal-breaker for me, but it would be nice to give people the option to see the watch face when they flick up their wrist. It would definitely get worse battery life, but probably no worse than Android Wear. Hopefully anyone buying the watch would be smart enough to not have incredibly active and colorful screens on full brightness all day, maybe that is Samsung's worry though.
    11-09-2014 05:59 PM
  12. Active55's Avatar
    My full watch face comes on with the flick of the wrist in a little dimmer than full on, but it's all there; the nice looking blue one with 12 and 6, plus hash marks. I have the brightness setting at "automatic." Don't know if there are others setting yet...
    11-09-2014 06:04 PM
  13. karsdroid's Avatar
    that's the only one that will do that and i'm not a fan of it....too messy. i don't want to be locked into one watch face
    11-09-2014 06:19 PM
  14. foxbat121's Avatar
    No Android wear has an AMOLED screen this large. Larger screens consumes more power. The thing with gesture is that many times, you don't mean to take a look at the watch when you swing your arms but the watch can often mistake your motion. I can understand why Samsung did that. And certainly not a deal breaker for me.
    11-09-2014 06:23 PM
  15. foxbat121's Avatar
    If you read the instructions on Power Save mode in the settings, it seems that Samsung is indicating that using gray-scale home screen saves power. So this motion gesture watch face follow the same rule: gray-scale watch face only, no colors. Same for all stock watch faces.
    11-09-2014 06:28 PM
  16. jspring86's Avatar
    While it is true that no Android Wear watch has this big a screen, I still get much better battery life on the S than on my 360 so fa. I imagine even if the screen were fully on when you flick up your wrist, I could still get a day out of this watch. No way to know without the option though. Either way, I'm pretty happy so far
    11-09-2014 06:29 PM
  17. karsdroid's Avatar
    i totally get why theyve done it, its just after having my full watch face on my original gear with a flick of my wrist i dont want to take a step backwards....
    11-09-2014 06:44 PM
  18. Active55's Avatar
    I bet additional watch faces will be available soon. Maybe something to your liking in the near future??? My guess is a third party is going to make something awesome that will blow peoples minds on this great screen in time...
    11-09-2014 07:20 PM
  19. Mom2Ninjas's Avatar
    I would hardly call this a step backwards. Lol
    11-09-2014 07:21 PM
  20. ougum1's Avatar
    Nope. I use the gold one, and it come up full screen every time I flick my wrist. Every time.
    11-09-2014 08:04 PM
  21. sux2bu's Avatar
    I found a fix for your problem.
    At first I was gonna say your watch might be defective, but then I remembered my watch did the same thing when I first got it. But after fidling with a bunch of stuff I couldn't get it to do that same thing again. I hate little problems like this and it really bugs me until I solve it. So, I went through every setting and found out what caused it.
    I hate when I would look at my watch a while after receiving a text or something and the screen would go back to the clock after it went dark. This bugged me the most was when I was reading a grocery list the wife text me. I would be looking at the list, get the milk, look at my wrist again a to see what was next and it would show the clock. So I loved the "settings" "display" "wake up screen" "last screen" feature. That way after my watch goes dark and I flick my wrist it goes right back to my grocery list text and I don't have to scroll through again and find it.
    So what does this all mean for you? If you think about it the last screen you look at on watch (as long as your not in an app) will be the full clock face, you can't go back to the dim face after you see the full face. So after it goes dark and you have the "last screen" feature set, when you flick your wrist you will see the full watch face again.
    You're welcome.
    11-09-2014 08:06 PM
  22. jspring86's Avatar
    Worked for me, solid tip!
    11-09-2014 08:50 PM
  23. mlctulsa's Avatar
    You're welcome.
    You are right. It works. Take some time to see what kind of hit battery power will take, however.
    11-10-2014 11:57 AM
  24. sux2bu's Avatar
    That's how I've been using it since 30 min after I got it and I've been averaging 50% battery in a full day. It's not always on, but I am trying out always on today.
    11-10-2014 02:05 PM
  25. Active55's Avatar
    Hmmm... all my watch faces do that??? I switched to the brown/gold/blue and like it better.
    11-11-2014 10:38 AM
42 12
  1. How to disable this Mobile Data is Off message on Verizon Note4?
    By Andy847 in forum Samsung Galaxy Note 4
    Last Post: 01-11-2017, 01:08 AM
  2. how to check if 16 or 32 gb capacity on your nexus7
    By Georgey James in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-14-2014, 02:03 AM
  3. Replies: 4
    Last Post: 11-09-2014, 01:45 PM
  4. Replies: 2
    Last Post: 11-09-2014, 12:45 PM
