Hi,
Notifications for Gear S you can find it at Google Play and Samsung Galaxy store and use rich notifications in order to send notifications to your new Gear S AND Gear S 2.
Better always from Google Play because in a few hours I can update the App.
It allows you to answer notifications from your Gear S but not always. In case of whatsapp the app will allow you to reply if there are no messages unread in whatsapp, but the App is always learning. Try it!
Now you can send new WhatsApp messages from it. Read the Help.
You can select between using predefined messages or a default keyboard in order to reply some notificacions like whatsapp, gmail and hangouts. In case you want to add your own predefined messages you have to edit the file you will find at your sdcard root called: GearOptions.txt
If you have problems you can write here in order to share your problems with other people and I will answer it soon.
Try to select some notifications for this App and other for Samsung Gear Manager, but no select the same notification in both Apps.
Default Screen App in only valid if you select at settings that the App asks you if you want to receive other notifications different of default supported ones.
Please, let me know if they work for you and give me feedback.
You can find it at Samsung Galaxy Apps and Google Play https://forums.androidcentral.com/e....gear.notificationsgears&hl=es&token=uDmP_1vO
Thanks
