i want to know if i can create a new whatsapp message or i can only view a notification without replay with a complete message using the samsung gear s keyboard
you cannot create a new WhatsApp message on the phone with this app. You can reply to a WhatsApp message using this app, there is a setting in the app to use either the Gear S keyboard or canned reply. As far as I can tell it is an either/or proposition for the replies, that is either you used the keyboard or the canned replies, you cannot switch between them on the fly (which would be a nice feature to have).
Hola Paco. Can you send the new version to me thru mail as you sent the 2nd one? I bought in the Samsung store and I think you did not updated there right?
I keep getting Google now notifications even though I have them turned off in both Notifications and the Gear manager. It's annoying, every couple of minutes I'll get a traffic alert, weather alert, sports score, etc. Google search is what I have Unchecked, is there something I'm missing? The notification is in Notifications for Gear S app.
Does anyone know if this app will allow texts to be answered through Contacts+? I am getting more and more interested in this app and that would be the deal-maker for me!!! Thanks for any info!
P.S. Let me as this while I am at it....do texts answered via a 3rd party app through this app create 'conversations or threads' like the stock one does?
Still getting random Google now alerts from the notifications for gear s apps, weird. For some reason I'm not getting other alerts at all from the app, only Google now ones, which is the one I have unchecked in settings. I'm unable to get this app to really work on my gear S.
Hi,
did you select one kind of notifications for this App and the rest for Gear Manager? Maybe there are conflicts with both Apps.
Icons seem to be changed after the new update. One problem I am facing is that the messages get truncated, I can't see the complete message, not sure it is sometime or everytime.
I have some apps duplicated. But even if I turn them off on gear manager I still don't get them through your app. I'll try and uninstall and reinstall to see if that helps.
thanks... so i cannot create a new whatsapp message from the gear s but i can to replay to any message?? can i replay with gear s full keyborard ? or only with porposition for replies?
