1. DivaDrekA's Avatar
    I have the Gear S (Verizon) and I'm on nested via bluetooth on my note 4. Whenever I receive text messages, I get the notification and able to read it on my Gear S, however, I am unable to reply. My only option is to dismiss it.
    If someone texts my Gear S number, I am able to reply. I prefer to be able to reply when messages come through to my note 4.
    I hope this isn't too confusing as you guys read this....any suggestions?
    11-11-2014 08:41 AM
  2. reesh11's Avatar
    Are you using the stock texting app? That is the only way you'll be able to respond.
    From my smokin' hot Note 4
    11-11-2014 08:48 AM
  3. DivaDrekA's Avatar
    I was using the verizon+ app that came pre-installed on the phone. I also have the original messages app which was also pre-installed. I will try switching.
    11-11-2014 08:55 AM
  4. daddyd302's Avatar
    So far, it only works with the stock Note 4 message app.
    11-11-2014 09:04 AM
  5. DivaDrekA's Avatar
    Thanks! It's working.
    11-11-2014 09:28 AM
  6. Active55's Avatar
    My AT&T unit being used as a cell phone without being paired or connected to another phone lets you respond to text messages from the "Messages" application, but not the right swipe "Notifications" screen. I did read a post here somewhere that there is an AP that will let you reply from the notifications screen. I'll try to find it and link... (Here it is)
    11-11-2014 09:29 AM
  7. arteebip5's Avatar
    Any idea how to reply to
    Facebook notification from the watch the Samsung website says u can but it only lets me
    Launch app on phone cheers
    11-11-2014 09:35 AM
  8. Mom2Ninjas's Avatar
    I'm not getting facebook or hangout messages/notifications... at all.
    11-11-2014 10:02 AM
  9. foxbat121's Avatar
    No app needed. Just swipe up a little bit and you will find the reply button on the bottom.
    Active55 likes this.
    11-11-2014 10:46 AM
  10. foxbat121's Avatar
    You can only respond to notifications on the watch if it is from an phone app that Samsung wrote. That means stock email app or stock message app.
    11-11-2014 10:49 AM
  11. arteebip5's Avatar
    There is no reply button for
    Facebook Twitter and what's app but Samsung site clearly says respond to Facebook notifications from watch
    11-11-2014 11:20 AM
  12. denilsonsantos's Avatar
    I'm using my gear S with Note 4. I have a S4 at home with android 4.4.2. I will move my gear to S4 to check if notifications work.
    11-11-2014 11:30 AM
  13. arteebip5's Avatar
    It's a weird one tbh can't figure it out
    11-11-2014 12:11 PM
  14. Active55's Avatar
    Thanks! Found that today by acident. Sometimes it's on the top right and sometimes it's on the bottom right. Lol... Those pesky triple dots!
    11-11-2014 03:08 PM
  15. foxbat121's Avatar
    Unless you are using a Samsung wrote facebook app (which I don't think existed), you can't reply to it. Read the description on Samsung's web site, they never mentioned you have reply to facebooks. Read those words carefully.
    11-11-2014 05:47 PM
  16. Michael Maloney1's Avatar
    go to the gear manager on your phone, hit notifacations, and check off all the app you wish to have theit notifacatons on your phone.
    11-11-2014 08:20 PM
  17. Mom2Ninjas's Avatar
    In theory this should work. Unfortunately, sometimes the notifications just randomly quick working.
    11-11-2014 09:59 PM
  18. foxbat121's Avatar
    Notification works reliably for me. Make sure you unchecked the box in Gear Manager that says limit notification when phone is in use. It is on by default.
    Reply to notification is another story. It seems only work if it is from a Samsung stock application like Messages and Email app on the phone.
    Sammuel1973 likes this.
    11-12-2014 08:09 AM
  1. Swipe keyboard on Android wear's roadmap?
    By tl600f4i in forum Android Wear / Wear OS
    Last Post: 11-23-2014, 07:46 PM
  2. Are They Dropping The Ball with the Nexus 9 on Black Friday?
    By roninmedia in forum Google Nexus 9
    Last Post: 11-17-2014, 01:00 PM
  3. Replies: 1
    Last Post: 11-11-2014, 03:39 PM
  4. Battery Life: At 96% only 1h 30m on Battery?
    By dogday007 in forum Samsung Galaxy S5
    Last Post: 11-11-2014, 12:05 PM
  5. Replies: 3
    Last Post: 11-11-2014, 09:15 AM
