1. noteiii007's Avatar
    Just got mine from tmobile today. Why would they make it so difficult to charge with watch? I have a hard time trying to position the cradle correctly to snap on the back. Takes me a few mins. I just don't get why they made it so difficult. It is worse then gear 1 for charging in cradle
    11-12-2014 12:45 AM
  2. terrain's Avatar
    same or very similar to Gear 2... I do it once a day so no biggie. Could they make it easier - yes. Will they - yes. Gear V.
    11-12-2014 01:22 AM
  3. CavumSubarachnoidale's Avatar
    Bad port in your mobile maybe. Or bad cradle. Go to shop with your warranty if you can. If not - try to use match or toothpick or something to get a necessary phone position at cradle.
    11-12-2014 01:29 AM
  4. daddyd302's Avatar
    I agree with the OP, the cradle is a PITA to use. I would of prefer the Gear 1 cradle over this, it was easier to use. It does take me a few seconds to charge mine.
    11-12-2014 03:15 AM
  5. foxbat121's Avatar
    Same here. No way to secure it in with out mess up the screen.
    11-12-2014 06:59 AM
  6. sux2bu's Avatar
    I don't know what you guys are doing wrong. I just put it under the watch and squeeze. Takes a whole 2 seconds.
    Active55 likes this.
    11-12-2014 07:40 PM
  7. foxbat121's Avatar
    'Cause we all afraid of crushing that beautiful screen
    11-12-2014 08:03 PM
  8. aitt's Avatar
    It's not just that simple because if it's not position right it will break the clasp. That why I positioned the bottom and snap to top. Taking off is tricky too.
    Sammuel1973 likes this.
    11-12-2014 08:10 PM
  9. BrianCioffi's Avatar
    Umm, it is pretty simple... Place the bottom of the cradle first (line up the gold charging connections), then snap the top. To remove, there is a little tab on the right side of the cradle that makes it very simple to 'pull' the cradle off. Success my first time using it, without reading instructions.
    11-13-2014 08:55 AM
  10. aitt's Avatar
    I'm pretty sure everyone knows it's "simple" and know about the release tab, but people have broken the clasp or the fasteners on the watch being broken with previous Gear Models, especially the Gear Live. Although not widespread, a breakage is a breakage. But I agree with you in put mines on the same way. But the clasp are very tight and can leave people with the impression they're gonna break something. 360 has the best charging solution of Qi.
    11-13-2014 09:53 AM
  1. Replies: 1
    Last Post: 11-12-2014, 12:54 AM
  2. 8 hour charge in 15 minutes from the Turbo Charger?
    By hannsoft in forum Motorola Droid Turbo
    Last Post: 11-12-2014, 12:21 AM
  3. Why can't I unpause aubible?
    By peteed1985 in forum Ask a Question
    Last Post: 11-11-2014, 08:22 PM
  4. Why does my phone not convert long sms messages to mms?
    By roedel09 in forum Samsung Galaxy S5
    Last Post: 11-11-2014, 08:01 PM
