1. Floridadomer's Avatar
    I was surprised when I hooked up my Gear S to my PC that 2 of the 4 gigs was already taken with the OS. I also had the Gear Neo and I could have sworn that almost all of the 4GB was available. Two gigs just isn't much for music, pics and downloaded maps. I am curious if this is the case on all of the watches or just the ones from T-Mobile?
    11-13-2014 09:05 AM
  2. foxbat121's Avatar
    Yes, same.
    11-13-2014 09:23 AM
  3. CehowardNote7's Avatar
    I was going to asked that question. If I hook up the Gear S to my PC via USB cable, I will be able to see the files and memory on the Gear S... Can I transfer files that way too??
    11-13-2014 09:33 AM
  4. Floridadomer's Avatar
    Yes you can. That is how I moved my music. There is a Music folder already there.
    CehowardNote7 likes this.
    11-13-2014 09:36 AM
  5. aitt's Avatar
    Yes 2GB small. An album takes ~90mb Texas Maps for Here took ~250.
    While small it's suffice personally for me as I don't plan on have loads of albums and only plan to take what I need for workout. Anything beyond that phone is with me.
    But yes, that's a big OS for a little device.
    11-13-2014 09:38 AM
  6. CehowardNote7's Avatar
    Done that, and I am on a roll!!
    Another question, how can I change the NAME of the Gear S?
    Thanks again,
    11-13-2014 10:20 AM
  7. Floridadomer's Avatar
    Open Gear manager on your phone. Tap on the first line where it says Gear S and it will have an option to change the name.
    11-13-2014 10:31 AM
  8. aitt's Avatar
    Thanks again,
    Do that in Gear Manger if you click the device name on the home screen.
    11-13-2014 10:32 AM
  1. New to the lg g watch have question
    By reelon in forum LG G Watch
    Last Post: 04-30-2015, 09:44 PM
  2. Replies: 1
    Last Post: 11-26-2014, 01:08 AM
  3. New to M8 with a question
    By staticK78 in forum HTC One M8
    Last Post: 11-14-2014, 03:15 AM
  4. Why am I getting error messages saying that I don't have enough storage space?
    By idhayakani in forum Legacy Android & Other OS's
    Last Post: 11-14-2014, 01:25 AM
  5. question about jellybean upgrade for a used phone
    By jaifra78 in forum Legacy Android & Other OS's
    Last Post: 11-12-2014, 01:03 PM
