Curous if anyone has paired and setup the Gear S with a Samsung 10.1/12.2 phone enabled phablet ?
Gear Manager only works on phone, not tablet, AFAIK.
The definition of phone is related to the UI. Tablet UI is very different than phone UI even though they are running the same Android version.
I guess if you can install Gear Manager on it, you may try.
I have a 12.2 pro and it has its own number but what makes it phone enabled
Sent from my SM-P905V using Tapatalk
I have the galaxy note 12.2 lte verizon and I installed gear manager and it wouldn't pair
Sent from my SM-N910V
AT&T uses 800 and 1700 bands for LTE.
I am not sure if I can contribute to the discussion, but on a separate thread I was asking about a similar phone/tablet, the Tab 4 7.0 SN-T235Y, an international unlock that can make calls equivalent to 3g/4g on Tmobile and AT&T. However, during the scan pairing process of the Gear S, it didn't pick up, although my Gear 2 was fine. Yes, I was able to get the latest version of the Gear Manager. I wonder if Samsung will update their list of compatible devices with the Gear S as they did for the Galaxy Gear and Gear 2.
