So I have to give my review but my initial thoughts is solid after doing an exchange because the touch volume didn't work.
If you do plan on buying I strongly suggest pairing them through Gear and not thru Bluetooth settings. I think that's everything started off wrong.
However I am able to both pair to my Note 4 and the Gear S. I think some people said they could not transition from the Gear S to BT headphones if the Gear was connected to the phone. If that is the case I can tell you that you can with the Gear Circle. It successfully showed a Bluetooth headphone option and not the device I previously experienced with other bluetooth headphones. I think that may have to do with Gear Manager downloading software after the initial sync.
Gear manager will show you battery life for the circle and custom setting you can manage.
In addition you will not have issues controlling the media being played through your phone and controlled by your Gear S. They work effortlessly.
Happy hunting.
Happy hunting.
