1. dorrien12's Avatar
    Ok so I had it on a little tight and afterwhile it felt funny. It seems to make my wrist sweat. So I loosened it and it still feels the same way. Gonna wear on other wrist for a day or so and switch back to see.
    Anybody else having discomfort issues while wearing and loving their new Gear S?
    11-24-2014 04:01 AM
  2. rellim's Avatar
    Not me...wear it all day and in gym for an hour with no problems.
    11-24-2014 11:05 AM
  3. c1971ace's Avatar
    It does a little bit but not enough to be a big deal to me
    11-24-2014 01:08 PM
  4. dorrien12's Avatar
    I had two other bracelets on that I usually wear on my other wrist, I believe they were the culprit. We will see.
    11-24-2014 04:41 PM
  5. xendula's Avatar
    After a run, there is a tiny bit of sweat underneath, but not from usual wear, no.
    11-24-2014 04:46 PM
  6. InfamousUnknown's Avatar
    I haven't noticed any from normal wear, I wore it twice on a bike workout and didn't have any more sweat there than the rest of me.
    11-24-2014 04:59 PM
  7. jlczl's Avatar
    Does your battery last all day?
    Back on topic, no sweat issues for me either.
    11-24-2014 06:51 PM
  8. dorrien12's Avatar
    Brightness: Auto (slightly dim)
    Screen timeout: 30 seconds
    Motion: Unchecked wake up gesture (also turned off from phone in Samsung Gear)
    Bluetooth: on
    WiFi: off
    Mobile: Auto/off
    Forwarding: on
    Remote connect: only when needed
    Notifications: calls/missed calls, sms, family map, alarm.
    Battery usage:
    First day: 15.5 hrs
    Used battery charger (got 41% from it) after got another 14hrs
    Second day: 16.5 hrs.
    Third day: had off charger since Sun 9am (so far 22 hrs), am at 51%. (Got a few phone calls and a few text messages.
    36 hrs @ 10%
    11-24-2014 08:41 PM
  9. dorrien12's Avatar
    Only notifications; phone, & sms,
    11-24-2014 08:42 PM
  10. jlczl's Avatar
    Thanks for those settings. I've adjusted a couple of mine to match yours and hope to get better battery life. How about location? Do you have that on? I just noticed I did and I don't think I need it on so I turned it off.
    11-25-2014 09:17 AM
  11. dorrien12's Avatar
    I don't use the location either.
    I have changed two settings;
    1) I now have auto forwarding off, it was showing the gear number when I called someone.
    2) Remote Connect is on - so when loose Bluetooth connection I can use the phone on the gear s.
    11-25-2014 02:42 PM
  12. ebosco3's Avatar
    Mines a little but it's ok , when you lift your arm to check time does your notifications' show ? On mine I have lift arm then tap again to show notifications
    12-14-2014 07:51 AM
  13. dorrien12's Avatar
    Not sure, I leave motion off.
    12-14-2014 08:42 AM
  14. Primetimeplaya's Avatar
    Leave your watch set so that it awakes to the last screen it was on before the screen goes to sleep. Then set your notifications to list form. With those settings, you should see your list of notifications when your raise your arm to look at the watch.
    12-14-2014 10:16 AM
  1. Replies: 2
    Last Post: 03-21-2015, 11:18 AM
  2. Gear S + Moto Hint = Super cool
    By jerrydanny in forum Samsung Gear S
    Last Post: 12-14-2014, 11:55 AM
  3. Why is my Samsung Galaxy Note 10.1 gt-n8013 having screen display?
    By Oduronke Eyitayo in forum Samsung Galaxy Note 10.1
    Last Post: 11-24-2014, 12:36 PM
  4. New to Samsung Galazy S3 Mini ....... what is safe mode for?
    By Hazel Timpe in forum Ask a Question
    Last Post: 11-24-2014, 10:32 AM
  5. Replies: 1
    Last Post: 11-24-2014, 06:43 AM
