Save big with this Prime Day deal on theNVIDIA Shield TV
03-22-2019 03:16 AM
171 123 ...
tools
  1. lyingfromyou's Avatar
    Picked up my Gear S from Sprint yesterday. I love the main watch face! (The one pictured in most ads) Where can I find more high quality watch faces?? I am willing to pay as long as it's clean!!! Thanks!
    zivelik likes this.
    12-04-2014 06:16 AM
  2. riceastwood's Avatar
    Big watch face is a good one
    12-04-2014 01:45 PM
  3. lyingfromyou's Avatar
    It is nice. I've seen it around the app store! Anything or anywhere else I can look?? I have been to xda, used the designer, and used Google.... Is it just still too young yet to be expecting a good clean selection??
    djcarr628 likes this.
    12-05-2014 05:31 AM
  4. pwscott's Avatar
    I too wish there were more selections that work and look good on Gear S.
    If you look here at Gearfaces.com, and scroll down on the main page, there are (8) watch faces for Gear S that work for Watchstyler. They're .owsc files. Now we just need more of them and better looking ones.
    12-07-2014 08:24 AM
  5. Ntchwaidumela's Avatar
    Rest assured, there will be many available in the coming months. Be patient.
    lyingfromyou likes this.
    12-08-2014 01:26 AM
  6. Lanhoj's Avatar
    I released a set of Clock Faces for the Gear S last week-> https://play.google.com/store/apps/d...n.zooperweargs
    There's also a free/TRIAL version-> https://play.google.com/store/apps/d...wearablestrial
    Keep in mind though that they require the paid version of Zooper Widget to work.
    12-08-2014 12:53 PM
  7. byrds8's Avatar
    Is there no way to remove the 0 from the clock when in AM/PM view? Also how can I have the links to things change and open apps I want instead of what they are trying to open?
    12-08-2014 09:04 PM
  8. Lanhoj's Avatar
    Is there no way to remove the 0 from the clock when in AM/PM view?...
    If you don't want a "0" (example: 02:45):
    (from within Wearable Widgets)
    1) Tap the Zooper Widget
    2) Tap "Configure Widgets*
    3) Tap "Layouts"
    4) Locate "Time" & tap it
    5) Locate the "Edit Text Manually" & tap it
    you'll see "#DHH:mm#"
    6) Change "HH" to "h"
    7) Tap the "Checkmark" icon in the upper right corner
    That's it!
    ...how can I have the links to things change and open apps I want instead of what they are trying to open?
    To change the App that launches:
    (similar to the steps I outlined above)
    4) Locate the item you want to change & tap it (example: "SMS Icon" )
    5) Locate the "On-Tap action" & tap it
    6) Choose the App you want to launch instead
    (if you're using a design that includes "Red Bubble" and/or "Notification Count", repeat for those items too)
    That's it!
    Note: Keep in mind launching the Apps only works when it's used as a Widget not a Clock Face.
    12-08-2014 10:31 PM
  9. Tom Leith's Avatar
    My newest face
    budgitApp likes this.
    12-09-2014 10:02 PM
  10. Floridadomer's Avatar
    My newest face
    GO IRISH!!!!
    Ntchwaidumela likes this.
    12-11-2014 08:10 AM
  11. dorrien12's Avatar
    My latest creation.
    12-18-2014 11:17 PM
  12. Ntchwaidumela's Avatar
    dorrien12: This is very very nice. Have you put it on Samsung Apps yet? Do you plan to do so?
    12-19-2014 01:17 AM
  13. dorrien12's Avatar
    Thanks a bunch, glad someone else likes it as much as I do.
    No I haven't put it on the site, I'm not sure how to do it. Where would I go to learn?
    12-19-2014 07:18 AM
  14. Ntchwaidumela's Avatar
    I'm not sure. You can check with the moderator for this forum.
    12-20-2014 04:41 AM
  15. hodori475's Avatar
    I used adobe illustrator and photoshop to make the watch face and then used watch styler app. It's a first attempt.There is also two hidden short cut buttons. ( basically the short cut keys are the same color as the background or you can set the transparency to 100% after positioning.)
    Thought this info would help as far as designing something custom.
    made with adobe illustrator and photoshop
    12-23-2014 08:52 PM
  16. dorrien12's Avatar
Name:	tag gear s2 .jpg
Name:	breitling gear s.jpg
    That's awesome!!!
    12-23-2014 10:25 PM
  17. mikeyking's Avatar
    Fab - any chance of the actual files which we can put into Watch Styler for this one please?
    12-24-2014 02:50 AM
  18. hodori475's Avatar
    If You click on the images posted and "save as" The quality should be good enough to use on watch styler. It will be about 364kb. The original is about 1.08mb. For the Breitiling I set the top black box for the date and the bottom black box for the battery. I also made a full screen version of the tag heuer red face. I'll post some more images when I have time to make new designs. I'm also open to any design ideas. If it's interesting enough, I may try and make it.Gear S Watch Faces-tag-gear-s-full.jpg
    dorrien12 and mikeyking like this.
    12-25-2014 04:59 AM
  19. hodori475's Avatar
    Infinity Icon, 3 , 9, 5, and 7 o'clock have shortcut keys over them set with 100% transparency.
    For some reason the camera made the red look orange on the minutes.
    Adobe photoshop and illustrator.
    12-25-2014 09:30 AM
  20. mikeyking's Avatar
    Still awaiting my Gear S. I've got a Gear first series and I use watch faces, edit the png files, put it into the .wstheme format and use it as a watch face. Is that what everyone is doing?
    How do you create watch faces on the Gear S? Are there instructions somewhere? Cheers
    12-29-2014 01:38 PM
  21. sjaduae's Avatar
    No I think they are all using the new gear S watch styler app which has all the instruction included.
    You can DL this to your phone now and make your own creations by making a jpg background and storing it in your phone gallery so the app can use it, then add your hands, dates, app shortcuts etc anywhere on your created background from the styler app
    Tip: To add more shortcuts but they are cluttering the screen you can place them say over the dial numbers eg V and make them 100% transparent in the settings, I have 3 each hidden under the V VII and XII. This saves having to make an app bar area which makes your watch face smaller
    You can then put them on your watch using the new Samsung gear manager or export the them to others in a OWSC file format
    BTW to post a screenshot of your dial by holding the home button and swipe left to right at the same time
    mikeyking likes this.
    12-29-2014 08:21 PM
  22. McMender's Avatar
    Hello,
    is somebody able extract from Gear S the standard Samsung Blue watch face??? And post it?
    If not full set, than minimally the blue background.
    May be somebody who have root could do it.
    I would like to some small changes - ad BT status, eventualy connection to Mobile network status, eventualy digital time.
    12-30-2014 11:36 AM
  23. sjaduae's Avatar
    Hello,
    Why not screen shot it yourself and edit the image and use watch styler to add in your options etc, although network status is not available
    12-30-2014 12:15 PM
  24. Mercedes Pinder's Avatar
    I have got the watch styler on my Samsung note 4. I can change the colours make Stert and icons smaller etc. But I cannot reposition things so ends up a cluttered mess. Am I doing something wrong?
    12-31-2014 05:08 AM
  25. lyingfromyou's Avatar
    You should be able to do a long press on that item to get it to move.... Your Stylus will help!
    Mercedes Pinder and teejay69 like this.
    12-31-2014 05:50 AM
171 123 ...
  1. LG G G2 Rear Facing Camera Issue
    By Sarpool in forum LG G2
    Last Post: 12-05-2014, 12:35 AM
  2. Got A Survey Call About The Gear S
    By aitt in forum Samsung Gear S
    Last Post: 12-05-2014, 12:27 AM
  3. LG watch
    By Muffdawg69 in forum Legacy Android & Other OS's
    Last Post: 12-03-2014, 08:33 PM
  4. Does Anyone Else Have Severe Lag/Choppiness on Their Front Facing Camera?
    By MayonnaiseOreo in forum Motorola Droid Turbo
    Last Post: 12-03-2014, 08:00 PM
  5. Replies: 0
    Last Post: 12-03-2014, 04:49 PM
