1. Jeff Weeks's Avatar
    I have a question about using Voice recognition when i'm going to send a text message. when I hold the 123 button on the keyboard in the bottom left coroner, the keyboard options screen pops up. The microphone is grayed out though. Is there a option to turn this on? Also I can double click the home button and voice commands will work here.
    12-06-2014 12:42 PM
  2. sampson0420's Avatar
    with mine, you hold the space bar when in keyboard mode.
    12-06-2014 12:46 PM
  3. Jeff Weeks's Avatar
    I tried that also, and nothing happens. Thanks for the suggestion though. I'm going to try a factory reset and see what happens.
    12-06-2014 05:32 PM
  4. Primetimeplaya's Avatar
    Someone else was having the same problem a couple days back. I'm not sure why it's grayed out. There's no special setup for it. You should be able to hold the spacebar for a second and then the little mic should pop up on the screen. Press it and speak.
    12-06-2014 05:58 PM
  5. Jeff Weeks's Avatar
    I had been chatting to a Samsung via text. There saying I should have a Google keyboard installed as well as Samsung. I only Have Samsung under Settings/Language&Input. I have also Finished a factory Reset.
    12-06-2014 06:20 PM
  6. Primetimeplaya's Avatar
    You still having the same issue after the reset?
    12-06-2014 06:41 PM
  7. Jeff Weeks's Avatar
    Yep, same issue still. After talking to Samsung again, they told me I need to bring the watch in to a authorized Samsung dealer for them to look at.
    12-07-2014 01:51 PM
  1. Camera question
    By tbolt86 in forum Samsung Galaxy Note 4
    Last Post: 12-26-2014, 07:50 PM
  2. Lollipop: When Will The Tab S Get 5? And One Other Question.
    By mlauzon in forum Samsung Galaxy Tab S 10.5
    Last Post: 12-08-2014, 03:12 AM
  3. Questions
    By girl_Interrupted513 in forum Google Nexus 6
    Last Post: 12-07-2014, 07:29 PM
  4. Question about updating to KitKat without losing wifi hotspot....
    By garythfla in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 12-06-2014, 04:00 PM
  5. New Moto X user - couple basic questions
    By nickacs in forum Moto X (2014)
    Last Post: 12-05-2014, 05:58 PM
