1. Sammuel1973's Avatar
    As usual, I charged it overnight, pressed the power/home button this morning, nothing happens. I will call TMobile and Samsung. I don't remember if it's still under warranty, got it at release date.
    04-18-2015 03:32 PM
  2. DLK1's Avatar
    Have to tried to charge it from a PC USB Port, seems like some folks have had luck with it charging from there. You may want to take a look at this link:
    http://forums.androidcentral.com/sam...arge-turn.html
    Sammuel1973 likes this.
    04-18-2015 05:00 PM
  3. mountainbikermark's Avatar
    Have you tried holding the power button for more than a couple of seconds? If it's "frozen" asleep holding the power button for 20-30 seconds should do a soft reset ( unfreeze it, power it down, power it back up).
    Hope that helps and please chime back when you get it going again and how you got it going. Thanks.
    04-18-2015 05:29 PM
  4. Sammuel1973's Avatar
    You guys are awesome! My Gear S is now working again. As instructed, I pressed the power button more than 10 seconds, the screen finally came on, but quickly went off, cuz of no battery, which is odd cuz I charged it every night. Anyway, it took about 2 hours of charging, I am now back in business. Thanks again!
    sirCLD and mountainbikermark like this.
    04-18-2015 08:46 PM
  5. DLK1's Avatar
    That is great glad this worked out for you, have a good evening!!
    04-18-2015 09:08 PM
  1. Replies: 6
    Last Post: 08-27-2016, 12:41 PM
  2. Note 10.1 (2014) not syncing S-notes with Note 4
    By jodroid03 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-19-2015, 02:07 AM
  3. Why is my Samsung Galaxy Note 2 turning on and off by itself?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 04-19-2015, 12:41 AM
  4. Anyone using ATT Straight Talk?
    By bradbamford in forum Samsung Galaxy S6
    Last Post: 04-18-2015, 06:24 PM
  5. Help in update
    By Sergey Baturin in forum Samsung Galaxy Alpha
    Last Post: 04-18-2015, 02:50 PM
