I have a Samsung Tab S 10.5. It's been update to Lolipop 5.0. been trying to connect my Gear S watch but it is not compatible. What can I do to make it coonect ? Thank you.
Are you able to install the Samsung Gear app on the Tab? It is found in the Galaxy apps store. If that doesn't show up when you search for it then I would say it's unlikely that you can use the watch with the Tab.
There are many reports that Gear Manager on Samsung tablets' are not compatible with Gear S. I have not heard anyone successfully pair it with any Samsung tablets.
