1. Oliveiro69's Avatar
    I have a Samsung Tab S 10.5. It's been update to Lolipop 5.0. been trying to connect my Gear S watch but it is not compatible. What can I do to make it coonect ? Thank you.
    04-29-2015 01:01 AM
  2. anon(5719825)'s Avatar
    Are you able to install the Samsung Gear app on the Tab? It is found in the Galaxy apps store. If that doesn't show up when you search for it then I would say it's unlikely that you can use the watch with the Tab.
    04-29-2015 02:47 AM
  3. foxbat121's Avatar
    There are many reports that Gear Manager on Samsung tablets' are not compatible with Gear S. I have not heard anyone successfully pair it with any Samsung tablets.
    04-29-2015 02:02 PM
  1. Replies: 2
    Last Post: 05-31-2015, 03:31 PM
  2. How do I get this serial number?
    Last Post: 04-29-2015, 01:05 PM
  3. Why doesn't my S3 turn on unless its charging?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 04-29-2015, 12:58 PM
  4. Is there a way to disable the home button vibration on Lollipop?
    By alighadimipour in forum Sony Xperia Z2
    Last Post: 04-29-2015, 12:57 PM
  5. my note 2 turned off & can't start again
    By Hamza Mourad in forum Samsung Galaxy Note 2
    Last Post: 04-29-2015, 12:56 PM
