07-12-2018 03:04 PM
38 12
tools
  1. anystar's Avatar
    I have for the first holder in Shapeways looked for a price. The price was too high . 50 % more than in my town .
    05-11-2015 03:27 PM
  2. TB-1599's Avatar
    ouch.
    05-12-2015 12:09 PM
  3. Bikerscout1599's Avatar
    I had a friend of mine print one for me. (should be getting it in the mail today.) I also modded a charging back I got off of Amazon. So the cable comes out the left side instead of the right (So it's nice and clean) I will post a couple of pictures today.
    anystar likes this.
    05-14-2015 03:12 PM
  4. millerjer24's Avatar
    05-27-2015 08:39 PM
  5. Bikerscout1599's Avatar
    And?
    LOL. Totally forgot to do this... Will snap a few today after work and post them.....
    05-28-2015 11:12 AM
  6. TB-1599's Avatar
    Ok I took a couple of quick pics (sorry they are a little dark.)
    I am using a charging dock I bought off of Amazon. Since this is the kind without a battery. I soldered the usb cable directly to the pins on the inside of the cradle. (some other slight modifications had to be done to do this.) second I removed the lower clip from the cradle it's self I then attached the cradle to the stand using double sided foam tape. To keep the watch attached I just close the clasp (just not lock it.) But because of this the base of the stand it's self had to be cut out a little in order for the band to close. Then I just use another strip of double sided tape and stuck it directly to the nightstand its self..
    one more pic with and without flash.
    kieso likes this.
    05-28-2015 08:58 PM
  7. bluegrassbandit42's Avatar
    Anyone willing to sell one of these 3D printed stands?
    My cradle just broke, and from what I'm reading, it would be money better spent, rather than buying a cradle that is just going to break again.
    My Gear S is white, so a white stand would be preferred.
    Please, just pm me...
    Thanks,
    bluegrassbandit42
    08-08-2015 09:00 AM
  8. kieso's Avatar
    I've been looking for someone to do the same. The file is out there somewhere to actually just get on a website upload it and they mail it to you. I'll see if I can find it.
    Found it. Look on the first page of this thread and you'll find a .rar file with the stl in it. Just a warning though if you use one of the websites they can be expensive. If you could find somewhere local to you it'll be cheaper.
    08-09-2015 08:51 AM
  9. bluegrassbandit42's Avatar
    Great! I didn't even realize it was in the .rar file.
    Thanks for the info.
    08-27-2015 04:12 PM
  10. jamesray0757's Avatar
    Thanks for posting that file! A buddy at work printed it out for me. I had him change the angle so it faces foward more instead of up. That way I put it on my night stand and its a night time clock.
    Attachment 175329
    Could you upload the file please I really like this
    01-16-2016 07:56 PM
  11. guydo's Avatar
    [Impression 3 D pour ma gear S
    Prix: 19 €
    ATTACH=CONFIG]218236[/ATTACH]
    cousssino likes this.
    02-29-2016 06:54 AM
  12. cousssino's Avatar
    HI guydo
    I just seen your pictures....I hope You will read this message....is it possible to order one pc of support!?
    have You any info!
    04-11-2017 10:11 AM
  13. imcauseofdeath's Avatar
    This is a fairly old post but, if anyone is interested in a printed version of this dock I can do it!
    07-12-2018 03:04 PM
38 12
  1. Concerns About the G4's Leather Back
    By ace8707 in forum LG G4
    Last Post: 05-10-2015, 11:46 AM
  2. Having trouble deciding on a tablet for school.
    By Tetrisash in forum General News & Discussion
    Last Post: 05-02-2015, 12:12 PM
  3. leather case for galaxy s6
    By css626 in forum Samsung Galaxy S6
    Last Post: 05-02-2015, 10:04 AM
  4. How to make more memory for apps?
    Last Post: 05-01-2015, 03:38 PM
