1. kirkturk's Avatar
    Sorry if this was posted before.
    Is there a way to control your camera on your phone with the Gear S?
    Like put your phone down on table and sit across from it, and view what your going to take picture of on your Gear S and control everything like from your Gear S?
    Thanks in advance
    Kirkturk
    05-31-2015 11:24 PM
  2. DonShock's Avatar
    Yes there is an app that does exactly that. I believe it's called Remote Camera or Camera Remote for $2 if I remember correctly. It works great. There's another one I haven't tried that seems to do the same thing called Look Behind.
    UPDATE: Just got a chance to double check the app name:
    Phone Camera Remote by Leonid Tsarev for $1.06
    kirkturk likes this.
    06-01-2015 04:45 AM
  3. priceslss's Avatar
    Look behind actually shows live video from your cameras. I use this when away from my desk at work or something. I don't think you can take pics with it unless I am missing something.
    06-01-2015 08:23 AM
  4. Ultraman666's Avatar
    Snapzy is another good one as well and its free
    06-01-2015 10:23 AM
  5. priceslss's Avatar
    I see it for android wear for $1 am I searching wrong?
    06-01-2015 12:11 PM
  6. kirkturk's Avatar
    DonShock I bought Phone camera, but don't know how to load it on my gear s. Any help on this matter?
    Thanks for all your help
    06-01-2015 01:57 PM
  7. DonShock's Avatar
    The Gear S uses Samsung's Tizen OS, not Google's Android Wear OS. So you can't get apps from the Play store for it. You need to use Samsung's Gear App store to get your apps.
    When you first set up your Gear S you should be instructed to install the Samsung Gear Manager app on your phone. Once that is done, when you open the Gear app there should be a Samsung Gear Apps selection. When you purchase the app from within Samsung's Gear App store it should install on your Gear S. If not, check the Purchased tab on the drop down menu and you should have the option to install it.
    Ntchwaidumela and kirkturk like this.
    06-01-2015 07:37 PM
  8. priceslss's Avatar
    I do not see it in the sammy store I looked there first.
    06-02-2015 07:48 AM
  9. DonShock's Avatar
    Is your phone an S6? Other people have mentioned a glitch where some apps aren't shown as available on the Gear App store and it's somehow tied to the store not recognizing the S6 properly.
    06-02-2015 10:27 AM
  10. Ntchwaidumela's Avatar
    Look for it in Gear Applications. It's only $0.99 now. Got mixed reviews, but, generally decent.
    06-02-2015 05:09 PM
  11. Ntchwaidumela's Avatar
    Search for it from the Gear Manager app in applications.
    priceslss likes this.
    06-02-2015 05:14 PM
  12. priceslss's Avatar
    no the note edge
    06-03-2015 11:14 AM
  13. priceslss's Avatar
    Found it $4.... SHEEEESH!
    Ntchwaidumela likes this.
    06-03-2015 11:15 AM
  14. Ntchwaidumela's Avatar
    I thought I saw it for $0.99 or $1.99.
    06-03-2015 03:33 PM
  15. pinkivy98's Avatar
    I have the Note Edge. I just purchased the app only a week ago & it was $1.06.
    06-03-2015 10:12 PM
  16. priceslss's Avatar
    In the gear store?
    06-04-2015 06:53 AM
  17. mountainbikermark's Avatar
    In the gear store?
    Do a search for remote camera. This is what appeared for me on the Samsung Gear app store
    Support Our Troops !!!
    Beast Mode 4
    06-04-2015 09:29 AM
  18. priceslss's Avatar
    Thanks I have the look behind and use it when I'm away from my desk at work sometimes.
    06-04-2015 12:31 PM
  19. pinkivy98's Avatar
    In the gear store?
    Yes
    06-04-2015 06:23 PM
  20. priceslss's Avatar
    Was speaking of Snapzy... sorry
    06-05-2015 09:05 AM
  21. Ultraman666's Avatar
    Snapzy is awesome it works great
    06-05-2015 09:19 AM
  1. Why isn't my S3 camera responding?
    By sanjaycbe in forum Samsung Galaxy S3
    Last Post: 06-01-2015, 12:48 AM
  2. How do you delete widgets off of aquos
    Last Post: 06-01-2015, 12:33 AM
  3. Replies: 1
    Last Post: 05-31-2015, 11:49 PM
  4. Why is my phone lagging?
    Last Post: 05-31-2015, 11:42 PM
  5. Why is my phone frozen after trying to reboot it?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 05-31-2015, 10:56 PM
