1. icellphones32's Avatar
    I seen an ad for one, I'm probably going to get today. I have tMobile, are there any cautions I should take? When I buy a phone from someone I make sure it isn't blacklisted or stolen, do I need to do the same with this watch? Do I need to get the imei or serial numbers first?
    06-23-2015 10:20 AM
  2. foxbat121's Avatar
    The only watch that will work for T-Mobile will be AT&T version or T-Mobile version. If it is AT&T version, make sure it is unlocked or you will have trouble unlocked it to use with T-Mobile as you will find no help from AT&T.
    06-23-2015 10:51 AM
  3. icellphones32's Avatar
    Cool thanks, it's a tmobile model so I'm told.
    06-23-2015 11:09 AM
  4. BarryH_GEG's Avatar
    If you look on eBay, half the T-Mobile Gear S' listed have warnings about "bad IMEI" or "still under installment contract." Both guarantee said watches will never work on T-Mobile's network because they're blacklisted. If blacklisted IMEI's are shared amongst carriers then it won't work on AT&T either.
    06-23-2015 04:27 PM
  5. icellphones32's Avatar
    So what do you suggest? I'm not looking on eBay, I've seen a few on craigs here in my area. I have t mobile as a carrier.
    06-23-2015 04:46 PM
  6. pinkivy98's Avatar
    I arrange to meet the person at a Tmobile store. I have them look up the IMEI number and I put the SIM card in to make sure it will work.
    icellphones32 likes this.
    06-23-2015 08:55 PM
  7. jackjack1969's Avatar
    But even if the IMEI is number is good when you buy it, can it still be blacklisted if the original owner stops paying payments on it if it was financed or if they walk out the door and report it lost to the insurance company?
    06-23-2015 11:31 PM
  8. BarryH_GEG's Avatar
    T-Mobile actually has a "IMEI Checker" on their website...
    Check if Your Phone is Eligible for the T-Mobile 4G Network | IMEI Status Check
    The accompanying text says...
    If a device is reported stolen, the device will be unusable on most carrier networks (including T-Mobile,) even if the SIM card is changed. Verify your IMEI number to ensure your device will work.
    So if a carrier blacklists a IMEI it is universal meaning a blacklisted T-Mobile Gear won't work on AT&T either. Caveat emptor.
    06-24-2015 09:22 AM
  9. pinkivy98's Avatar
    Yes...that's why I would meet them at the store and ask if IMEI is clean and if it is paid off. The owner is present so they should have no problems providing the info.
    The first clue you should have on whether or not the seller is on the up and up is when you tell them to meet you at a tmobile store so you can have everything checked. If they don't want to meet you there then I would stop all communication.
    06-24-2015 10:32 AM
  1. Where to buy a lg g4 battery cover??
    By GTkitty in forum LG G4
    Last Post: 07-19-2015, 12:33 PM
  2. Can I transfer Ebooks from my Samsung Galaxy Tab to a Kindle?
    By AC Question in forum Samsung Galaxy Tab
    Last Post: 06-26-2015, 08:14 AM
  3. My Gear Fit does not have "Sleep" Function
    By maxche in forum Samsung Gear Fit 1 & 2
    Last Post: 06-26-2015, 08:01 AM
  4. Replies: 2
    Last Post: 06-26-2015, 07:57 AM
  5. How can I retrieve my pictures from my Nexus 5?
    Last Post: 06-23-2015, 10:17 AM
