I already used my gear s for months successfully with my note 4. Always worked OK, also remote connection through WiFi or 3g went without hiccups. Yesterday I bought an edge+, I reset my gear to defaults and installed and ran gear manager. Pairing was OK. All seemed good, only the moment Bluetooth connection is lost the gear switches to WiFi and almost immediately says it cannot set up remote connection. Also on 3g is not working. I ticked the remote connection checkbox in gear manager settings but doesn't work. Already three times reset the gear and setup again, completely removed all gear manager components, no luck so far. Working seamless on Bluetooth, not through remote connection.
Any body with s6 edge+ experience the same?
