1. burton4550's Avatar
    Does anyone know if the Samsung Gear S is compatible with Spint's network?
    I'm considering getting one, and being told by some it is, and it's 10 dollars a month for talk , text and data, but then also being told it's not compatible.
    As far as I've read it's compatible with both CDMA and GSM networks, and takes a sim card, so technically, isn't it pretty much just another device, same concept as activating another phone on your account?
    04-22-2016 04:45 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    If you buy the Sprint version then it will work on Sprint. I do not think the Sprint version can be unlocked to work on GSM carriers though.
    05-04-2016 08:39 AM
  3. foxbat121's Avatar
    Gear S only comes with either CDMA or GSM (there is also a wifi only version for South Korea). Not both. And it is dual-band only which means you need to buy the version in your region, e.g. you need North American version for working on US carriers.
    CDMA version is carrier specific. So you will have to purchase Sprint version in order to work on Sprint. And Verizon version for Verizon. It is not possible to move to another carrier.
    AT&T version and T-Mo versions are basically the same (GSM) but still need to be unlocked before you can use it on another GSM carrier.
    05-09-2016 05:52 PM
  1. Can I add ram to a samsung tab S 8.4? Confused..
    By AC Question in forum Samsung Galaxy Tab S 8.4
    Last Post: 02-06-2018, 02:46 AM
  2. Phone is making a beeping sound
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-07-2016, 04:34 PM
  3. Has anyone tried the EEEKit full case/cover?
    By uvalaw in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 05-04-2016, 08:34 AM
  4. What is file dir for contacts?
    Last Post: 04-22-2016, 08:59 PM
  5. Is unlocked the same as unbranded?
    By ChilledPilchard in forum Ask a Question
    Last Post: 04-22-2016, 04:50 PM
